linear lines not consistant
Jbenson
Model of CNC Machine: 6040 CNC router engraver
Post by Jbenson »
I have a 6090 CNC using Aspire 11 and Mach 3. the issue is I made a test project that will create a 1", a 2" and a 3" line. I get the 1" to come out perfectly but the 2 and 3" lines are both longer than they should be with the 3" being even longer. I adjusted the "steps per" under the motor tuning in order to get the 1" to come out correctly but it seem the linearity isn't correct.
Anyone have any ideas?
thanks
IslaWW
Model of CNC Machine: CNC Controller Upgrades
Re: linear lines not consistant
Post by IslaWW »
Do not adjust axis resolution settings by cutting. Use a steel rule (Starrett is best) a narrow angle vbit and use nearly the full travel of each axis
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
Jbenson
Post by Jbenson »
(Do not adjust axis resolution settings by cutting. Use a steel rule (Starrett is best) a narrow angle vbit and use nearly the full travel of each axis)
Thank you for the reply
For clarification are you saying to create a file that moves the axis the total working length of the machine and measure the results?
MarshaJ847
Model of CNC Machine: Automation Technology KL-6590
Post by MarshaJ847 »
Use Mach3's axis calibration rather than your own file.
https://youtu.be/xLUViu65qXg?t=203
Videos explain better than I do.
In the Settings tab
just above the Reset button is an Axis Calibration 'Set Steps per Unit'
Choose an axis to calibrate
select a distance to move
after moving check the distance and enter it in to Mach 3
Mach will calculate the steps and offer to update.
Do this several times.
