hello
im new to the cnc world and am wondering what is a good software to run my cnc? i have vcarve pro but what software do i need to run the machine to do the carving? any help is appreciated
good software for cnc transfer
Re: good softwaree
Most 3018 machines come with GRBL control software.
Vectric has two GRBL post processors.
Use the mm one if you set up your machine in metric.
Use the inch one if you set up your machine in imperial.
You can create your VCarve projects in metric or imperial and the post processor will handle the conversion for the machine.
- Model of CNC Machine: Sienci Long Mill
Re: good softwaree
If you are looking for software to send the gcode to your CNC, I would recommend either UGS or gSender.
- Model of CNC Machine: built
Re: good softwaree
You also can OpenBuilds CONTROL - Machine Interface Controller https://software.openbuilds.com/
don't forget to use open builds post Prosser from the data base
Re: good softwaree
VCarve comes with a program called VTransfer which can be used to send the GCode to a GRBL type machine and do jogging etc.
Re: good softwaree
If your cnc machine has a forum then you might be best asking that question on their forum as all the users will be using the same machine. Vectric software can be used with many different types of machine & control software so there may not be so many people using the same set up you are.
I know nothing about grbl based machines but if the control software for them has a trial version you might be best downloading some & trying them out yourself
