Hello,
I have for a few months a MillRight Carve King CNC.
I use VCarve Desktop 10.5 and VTransfer. Everything's going well.
I launched my machining several times and I had 3 times bugs with VTransfer : the program is running, the CNC stops and I have no error message. She's losing the coordinates. I think she is losing communication. And after restart of VTransfer then it works again for hours. And suddenly it stops. I used the same programs several times. So it doesn't come from the gcode.
What leads could you give me to diagnose and help me solve this dysfunction please?
What other (free) software that VTransfer you could advise me on?
Thank you for your help.
I apologize for my English, I am French and I don't really know English...
VTransfer bug ?
- TReischl
Re: VTransfer bug ?
Don't apologize for your English, it is just fine.
First I would make sure that you are not getting electrical interference.
I would also make sure that nothing is running in the background that could interfere. You could start by making sure you have disabled the internet connection to your computer. Check your power savings settings too.
After that, I do not have a clue. . . .
Re: VTransfer bug ?
Thanks TReischl for your answer.
I've already disabled power saving and usb suspend.
But i don't disabled internet connection... i will try it.
(And more windows was updating... i've disabled it after)
Thanks for your help.
And for another program to replace VTransfer... any idea ?
Re: VTransfer bug ?
It may be worth inspecting the log file. In VTransfer go to File->Open Log File. But you would have to do it after the issue occurred.psac wrote: ↑Tue Jul 14, 2020 6:07 pmHello,
If you remember on which day it had happened, you may access all the log files in the following directory:
C:\Users\<your username>\AppData\Local\VTransfer\Logs\
Greg K
Re: VTransfer bug ?
Hi, thank for your help again.
This is my vtransferlog :
[2020-07-14 10:18:12.793] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 10:18:12.825] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 10:18:42.001] [App] [info] Using Grbl1 backend
[2020-07-14 10:18:42.405] [SPE] [info] Refreshing serial ports list
[2020-07-14 10:18:42.489] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 10:18:42.491] [SPE] [info] Serial port list refreshed
[2020-07-14 10:18:42.526] [App] [info] Connecting to COM3
[2020-07-14 10:18:44.819] [Main] [info] Controller confirmed
[2020-07-14 10:18:45.825] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:18:51.026] [Main] [info] Device change detected (7)
[2020-07-14 10:18:56.917] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:18:57.464] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:18:58.558] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:18:59.105] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:18:59.652] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:19:00.199] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:19:01.292] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:19:01.839] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:19:02.386] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:19:02.933] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:19:04.731] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 10:19:04.895] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:32:57.040] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:32:57.587] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:32:58.133] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:32:58.680] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:33:03.055] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:33:03.602] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:35:16.493] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:35:17.039] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:35:22.508] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:35:23.055] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:35:33.993] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:35:34.539] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:35:43.837] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 10:35:44.385] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:35:47.176] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:35:47.723] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:35:54.832] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:35:55.379] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:36:05.256] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:36:05.816] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:36:09.776] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 10:36:10.225] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:36:26.344] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\V-Carve 3 V45.gcode
[2020-07-14 10:36:26.828] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:57:33.273] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:59:49.444] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:59:49.991] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:59:51.085] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:59:51.632] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:59:52.726] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:59:53.272] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 10:59:54.366] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 10:59:54.914] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:04:16.210] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:04:16.757] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:04:23.319] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:04:23.866] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:04:48.528] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:04:49.127] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:05:03.462] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\V-Carve 2 V60.gcode
[2020-07-14 11:05:03.911] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:19:55.488] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 11:19:55.815] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:20:08.940] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:20:09.487] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:21:55.485] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:21:56.032] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:21:57.126] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:21:57.673] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:22:07.636] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:22:08.216] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:22:28.429] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\Contour 1_4.gcode
[2020-07-14 11:22:28.902] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:24:28.680] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 11:24:28.898] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:26:06.117] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:26:06.664] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:26:07.758] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:26:08.305] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:27:34.457] [SerialPort] [error] Error sending data: Un périphérique qui n’existe pas a été spécifié
[2020-07-14 11:27:34.571] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:27:34.573] [Main] [info] Controller state changed. Status: 13 Confirmed FALSE
[2020-07-14 11:31:03.395] [SPE] [info] Refreshing serial ports list
[2020-07-14 11:31:03.440] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 11:31:03.440] [SPE] [info] Serial port list refreshed
[2020-07-14 11:31:03.461] [App] [info] Connecting to COM3
[2020-07-14 11:31:04.272] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 11:31:04.276] [Main] [info] Controller confirmed
[2020-07-14 11:31:04.710] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:31:08.538] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:31:09.085] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:31:10.179] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:31:10.725] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:33:36.630] [Logging] [info] Destroy Logging
[2020-07-14 11:37:52.525] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 11:37:52.575] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 11:38:20.208] [App] [info] Using Grbl1 backend
[2020-07-14 11:38:20.214] [SPE] [info] Refreshing serial ports list
[2020-07-14 11:38:20.227] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 11:38:20.229] [SPE] [info] Serial port list refreshed
[2020-07-14 11:38:20.234] [App] [info] Connecting to COM3
[2020-07-14 11:38:22.173] [Main] [info] Controller confirmed
[2020-07-14 11:38:23.193] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:38:34.541] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 11:38:34.993] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:38:38.337] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:38:38.884] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 11:39:15.446] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\V-Carve 3 V45.gcode
[2020-07-14 11:39:15.954] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 11:49:40.661] [Main] [info] Device change detected (7)
[2020-07-14 11:49:46.489] [Main] [info] Device change detected (7)
[2020-07-14 12:02:38.261] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 12:02:38.698] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:12:35.339] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:12:35.886] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:12:36.432] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:12:36.979] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:14:11.589] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:14:12.135] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:14:15.526] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:14:16.073] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:14:16.620] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:14:17.167] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:15:05.980] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\V-Carve 2 V60.gcode
[2020-07-14 12:15:06.746] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:34:00.199] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 12:34:00.526] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:34:44.385] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:34:44.932] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:34:46.026] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:34:46.573] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:36:02.588] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:36:03.135] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:36:04.229] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:36:04.776] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:36:48.892] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\Contour 1_4.gcode
[2020-07-14 12:36:49.442] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:39:26.828] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 12:39:32.624] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:40:47.109] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:40:47.656] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:40:48.749] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:40:49.296] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:43:09.843] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:43:10.390] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:43:11.484] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:43:12.031] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:43:13.124] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:43:13.671] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:43:29.313] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 12:43:29.532] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:44:09.476] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 12:44:10.051] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:44:13.481] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 12:44:14.067] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 12:44:33.126] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\V-Carve 3 V45.gcode
[2020-07-14 12:44:34.387] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:07:55.278] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 13:07:55.496] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:09:17.746] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:09:18.293] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:09:18.840] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:09:19.387] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:10:16.809] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:10:17.355] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:10:23.918] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:10:24.465] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:10:27.855] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:10:28.402] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:11:06.609] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\V-Carve 2 V60.gcode
[2020-07-14 13:11:07.355] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:30:11.855] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 13:30:12.182] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:35:46.760] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:35:47.307] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:35:48.948] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:35:49.494] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:37:10.979] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:37:11.526] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:37:12.073] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:37:12.619] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:37:23.010] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:37:23.557] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:37:40.785] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:37:41.348] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:37:59.215] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 1\Contour 1_4.gcode
[2020-07-14 13:37:59.741] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:41:17.156] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:42:26.061] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:42:26.609] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:42:27.702] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:42:28.249] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:46:10.101] [SerialPort] [error] Error sending data: L’opération d’entrée/sortie a été abandonnée en raison de l’arrêt d’un thread ou à la demande d’une application
[2020-07-14 13:46:10.182] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:46:10.183] [Main] [info] Controller state changed. Status: 13 Confirmed FALSE
[2020-07-14 13:56:36.791] [SPE] [info] Refreshing serial ports list
[2020-07-14 13:56:36.894] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 13:56:36.894] [SPE] [info] Serial port list refreshed
[2020-07-14 13:56:36.913] [App] [info] Connecting to COM3
[2020-07-14 13:56:37.567] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 13:56:37.572] [Main] [info] Controller confirmed
[2020-07-14 13:56:37.895] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:57:23.833] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:57:24.380] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:57:25.473] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:57:26.020] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:57:27.661] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:57:28.208] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:57:39.145] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:57:39.693] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:57:40.786] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 13:57:41.333] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:57:45.599] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 13:57:45.713] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 13:58:26.014] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 13:58:26.562] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:19:33.010] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 14:19:33.556] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:20:55.369] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:20:55.916] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:21:21.736] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:21:22.283] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:21:23.376] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:21:23.923] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:21:25.018] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:21:25.564] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:21:55.086] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 Contour 1 V45 0,5.gcode
[2020-07-14 14:21:56.525] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:26:37.284] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 14:26:37.830] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:26:43.845] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:26:44.393] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:26:45.486] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:26:46.033] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:26:46.580] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:26:47.126] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:28:20.643] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:28:21.189] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:28:23.923] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:28:24.470] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:28:27.751] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:28:28.298] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:28:40.551] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:28:41.131] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:29:07.607] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\Contour 1_4.gcode
[2020-07-14 14:29:08.073] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:31:50.273] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 14:31:50.381] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:32:01.319] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:32:01.866] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:32:13.351] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:32:13.897] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:35:28.584] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:35:29.131] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:35:29.678] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:35:30.226] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:35:34.053] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:35:34.600] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:35:38.428] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:35:38.975] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:35:51.553] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:35:52.100] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:35:57.351] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 14:35:57.596] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:36:43.195] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 14:36:43.660] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 14:54:22.512] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 14:54:22.730] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 14:57:12.479] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 Contour 1 V45 0,5.gcode
[2020-07-14 14:57:13.025] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:02:25.611] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 15:02:25.719] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:02:50.076] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:02:50.626] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:02:53.929] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:02:54.476] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:02:55.570] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:02:56.117] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:02:58.851] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:02:59.398] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:03:21.936] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 Contour 1 V45 0,5.gcode
[2020-07-14 15:03:23.468] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:07:12.821] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 15:07:13.148] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:07:20.804] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:07:21.351] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:07:22.445] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:07:22.992] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:08:43.929] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:08:44.476] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:08:48.851] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:08:49.398] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:08:52.132] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:08:52.679] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:09:28.048] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\Contour 1_4.gcode
[2020-07-14 15:09:28.500] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:11:52.980] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 15:11:53.417] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:12:41.542] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:12:42.089] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:12:42.636] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:12:43.182] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:16:08.807] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:16:09.354] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:16:10.448] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:16:10.995] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:16:28.495] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:16:29.042] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:16:40.963] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 15:16:41.080] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:17:17.703] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 15:17:18.992] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:18:07.269] [App] [info] Emergency stop requested
[2020-07-14 15:18:07.272] [App] [info] Toolpath finished
[2020-07-14 15:18:07.349] [BaseSerialController] [info] Reconnect requested
[2020-07-14 15:18:08.115] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 15:18:08.214] [App] [info] Emergency stop requested
[2020-07-14 15:18:08.214] [App] [info] Toolpath finished
[2020-07-14 15:18:08.224] [BaseSerialController] [info] Reconnect requested
[2020-07-14 15:18:08.845] [App] [info] Emergency stop requested
[2020-07-14 15:18:08.845] [App] [info] Toolpath finished
[2020-07-14 15:18:08.881] [BaseSerialController] [info] Reconnect requested
[2020-07-14 15:18:10.084] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:18:13.804] [SerialPort] [error] Error sending data: Un périphérique attaché au système ne fonctionne pas correctement
[2020-07-14 15:18:13.913] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:18:13.915] [Main] [info] Controller state changed. Status: 13 Confirmed FALSE
[2020-07-14 15:18:14.222] [Main] [info] Device change detected (7)
[2020-07-14 15:18:14.247] [Main] [info] Device change detected (8004)
[2020-07-14 15:18:14.279] [Main] [info] Device removed (3)
[2020-07-14 15:18:14.282] [SPE] [info] Refreshing serial ports list
[2020-07-14 15:18:14.291] [SPE] [info] Serial port list refreshed
[2020-07-14 15:18:45.760] [Logging] [info] Destroy Logging
[2020-07-14 15:21:21.372] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 15:21:21.388] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 15:21:48.563] [App] [info] Using Grbl1 backend
[2020-07-14 15:21:48.568] [SPE] [info] Refreshing serial ports list
[2020-07-14 15:21:48.583] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 15:21:48.585] [SPE] [info] Serial port list refreshed
[2020-07-14 15:21:48.591] [App] [info] Connecting to COM3
[2020-07-14 15:21:50.525] [Main] [info] Controller confirmed
[2020-07-14 15:21:51.623] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:21:58.072] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:21:58.619] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:21:59.822] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:22:00.478] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:22:00.949] [Main] [info] Device change detected (7)
[2020-07-14 15:22:02.010] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:22:02.666] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:22:51.447] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:22:51.994] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:23:03.124] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:23:03.671] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:23:52.635] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 15:23:53.179] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:30:23.207] [SerialPort] [error] Error receiving data: L’opération d’entrée/sortie a été abandonnée en raison de l’arrêt d’un thread ou à la demande d’une application
[2020-07-14 15:30:23.214] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:30:23.215] [Main] [info] Controller state changed. Status: 13 Confirmed FALSE
[2020-07-14 15:30:23.247] [Main] [info] Device change detected (7)
[2020-07-14 15:30:23.252] [Main] [info] Device change detected (8004)
[2020-07-14 15:30:23.252] [Main] [info] Device removed (3)
[2020-07-14 15:30:23.256] [SPE] [info] Refreshing serial ports list
[2020-07-14 15:30:23.264] [SPE] [info] Serial port list refreshed
[2020-07-14 15:30:37.345] [Logging] [info] Destroy Logging
[2020-07-14 15:32:28.884] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 15:32:28.901] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 15:32:52.533] [App] [info] Using Grbl1 backend
[2020-07-14 15:32:52.540] [SPE] [info] Refreshing serial ports list
[2020-07-14 15:32:52.552] [SPE] [info] Serial port list refreshed
[2020-07-14 15:32:55.015] [Logging] [info] Destroy Logging
[2020-07-14 15:55:23.107] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 15:55:23.289] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 15:55:57.344] [App] [info] Using Grbl1 backend
[2020-07-14 15:55:59.437] [SPE] [info] Refreshing serial ports list
[2020-07-14 15:56:00.378] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 15:56:00.380] [SPE] [info] Serial port list refreshed
[2020-07-14 15:56:00.557] [App] [info] Connecting to COM3
[2020-07-14 15:56:06.802] [Main] [info] Controller confirmed
[2020-07-14 15:56:07.642] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:56:59.800] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 15:56:59.905] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:57:09.235] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 15:57:09.782] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 15:57:41.783] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 15:57:42.253] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:18:47.390] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 16:18:47.608] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:19:23.811] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:19:24.358] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:19:25.451] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:19:25.998] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:19:27.092] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:19:27.639] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:20:00.451] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:20:00.998] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:20:01.545] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:20:02.092] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:20:03.186] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:20:03.733] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:20:08.217] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:20:08.766] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:20:27.400] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:20:27.960] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:20:49.069] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 Contour 1 V45 0,5.gcode
[2020-07-14 16:20:49.748] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:22:50.749] [SPE] [info] Refreshing serial ports list
[2020-07-14 16:22:50.770] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 16:22:50.770] [SPE] [info] Serial port list refreshed
[2020-07-14 16:23:09.944] [SPE] [info] Refreshing serial ports list
[2020-07-14 16:23:09.953] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 16:23:09.953] [SPE] [info] Serial port list refreshed
[2020-07-14 16:23:32.265] [SerialPort] [error] Error receiving data: L’opération d’entrée/sortie a été abandonnée en raison de l’arrêt d’un thread ou à la demande d’une application
[2020-07-14 16:23:32.293] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:23:32.295] [Main] [info] Controller state changed. Status: 13 Confirmed FALSE
[2020-07-14 16:23:32.304] [Main] [info] Device change detected (7)
[2020-07-14 16:23:32.319] [Main] [info] Device change detected (8004)
[2020-07-14 16:23:32.319] [Main] [info] Device removed (3)
[2020-07-14 16:23:32.322] [SPE] [info] Refreshing serial ports list
[2020-07-14 16:23:32.330] [SPE] [info] Serial port list refreshed
[2020-07-14 16:23:36.622] [Logging] [info] Destroy Logging
[2020-07-14 16:33:28.943] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 16:33:29.061] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 16:34:01.035] [App] [info] Using Grbl1 backend
[2020-07-14 16:34:01.123] [SPE] [info] Refreshing serial ports list
[2020-07-14 16:34:01.233] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 16:34:01.235] [SPE] [info] Serial port list refreshed
[2020-07-14 16:34:01.242] [App] [info] Connecting to COM3
[2020-07-14 16:34:04.777] [Main] [info] Controller confirmed
[2020-07-14 16:34:06.107] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:34:12.633] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:34:13.180] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:34:23.024] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:34:23.571] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:34:38.118] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:34:38.665] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:34:53.214] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 16:34:53.433] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:35:08.274] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:35:08.821] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:35:28.184] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 16:35:28.674] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:38:07.553] [App] [info] Emergency stop requested
[2020-07-14 16:38:07.555] [App] [info] Toolpath finished
[2020-07-14 16:38:07.583] [BaseSerialController] [info] Reconnect requested
[2020-07-14 16:38:08.350] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 16:38:08.787] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:39:35.195] [Logging] [info] Destroy Logging
[2020-07-14 16:43:04.051] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 16:43:04.061] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 16:43:24.141] [App] [info] Using Grbl1 backend
[2020-07-14 16:43:24.145] [SPE] [info] Refreshing serial ports list
[2020-07-14 16:43:24.157] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 16:43:24.159] [SPE] [info] Serial port list refreshed
[2020-07-14 16:43:24.163] [App] [info] Connecting to COM3
[2020-07-14 16:43:26.108] [Main] [info] Controller confirmed
[2020-07-14 16:43:27.111] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:43:31.248] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:43:31.795] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:43:33.107] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:43:33.654] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:43:34.201] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:43:34.967] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:43:45.139] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:43:45.685] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:43:49.959] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 16:43:50.068] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:43:55.083] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:43:55.630] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:43:57.875] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 16:43:58.435] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 16:44:07.525] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 16:44:08.073] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:01:30.412] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 17:01:30.849] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:01:59.531] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 17:01:59.837] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:19:22.069] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 17:19:22.177] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:21:40.537] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:21:41.084] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:21:46.552] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:21:47.099] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:22:49.361] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 V-Carve v45.gcode
[2020-07-14 17:22:50.624] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:46:12.265] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 17:46:12.811] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:46:58.749] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:46:59.295] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:47:00.389] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:47:00.936] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:47:45.233] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:47:45.780] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:47:46.873] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:47:47.420] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:47:55.733] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:47:56.280] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:48:11.618] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:48:12.178] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:48:28.717] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\4 Contour 1 V45 0,5.gcode
[2020-07-14 17:48:29.247] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:53:39.868] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 17:53:40.414] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:55:16.664] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:55:17.210] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:55:18.304] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:55:18.851] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:56:55.101] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:56:55.648] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:56:58.929] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:56:59.476] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:57:10.478] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:57:11.019] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 17:57:37.694] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 4\Contour 1_4.gcode
[2020-07-14 17:57:38.176] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 17:59:49.750] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 17:59:50.296] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:00:57.561] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:00:58.108] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:00:59.202] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:00:59.749] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:01:02.598] [Logging] [info] Destroy Logging
[2020-07-14 18:05:18.932] [Logging] [info] Setup Logging, logging to C:\Users\Lilou\AppData\Local\VTransfer\Logs\debug_2020-07-14_0.log
[2020-07-14 18:05:18.942] [wxApp] [info] Started Vectric Transfer 2.1 (Build 187.7000.1121)
[2020-07-14 18:05:39.785] [App] [info] Using Grbl1 backend
[2020-07-14 18:05:39.792] [SPE] [info] Refreshing serial ports list
[2020-07-14 18:05:39.804] [Serial] [info] Found device on port 3 with name "Périphérique série USB" Extra info:
Microsoft
usbser
[2020-07-14 18:05:39.806] [SPE] [info] Serial port list refreshed
[2020-07-14 18:05:39.811] [App] [info] Connecting to COM3
[2020-07-14 18:05:41.739] [Main] [info] Controller confirmed
[2020-07-14 18:05:42.656] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:06:12.036] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:06:12.583] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:06:13.130] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:06:13.676] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:06:14.223] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:06:14.770] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:06:16.958] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:06:17.504] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:06:18.598] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:06:19.145] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:06:24.503] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 18:06:24.621] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:06:37.862] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:06:38.432] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:07:08.397] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 2\V-Carve 1 45.gcode
[2020-07-14 18:07:08.860] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:27:49.493] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 18:27:49.821] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:27:59.118] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:27:59.664] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:28:00.758] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:28:01.305] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:30:09.383] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:30:09.930] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:30:16.493] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:30:17.039] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:30:20.868] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:30:21.414] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:30:26.883] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:30:27.430] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:30:30.711] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:30:31.258] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:31:14.341] [App] [info] Running toolpath C:\Users\Lilou\Desktop\Fleur de vie 2\Contour 1_4.gcode
[2020-07-14 18:31:15.956] [Main] [info] Controller state changed. Status: 6 Confirmed TRUE
[2020-07-14 18:33:26.113] [Main] [info] Controller state changed. Status: 0 Confirmed TRUE
[2020-07-14 18:33:26.331] [Main] [info] Controller state changed. Status: 1 Confirmed TRUE
[2020-07-14 18:33:29.898] [Logging] [info] Destroy Logging
Re: VTransfer bug ?
Thank you very much for attaching the log file. It looks like a genuine communication error. It is unlikely a bug.
You may want to follow the advice from TReischl, as this was a quite common source of communication issues on various machines in the past.
Greg K
Re: VTransfer bug ?
I don't know how to check my electrical network to find out if there is interference.
It has the PC, the screen, the CNC and the spindle and the vaccuum.
It is possible that a refrigerator or freezer will start at this point.
I will try another PC to eliminate an USB problem on the PC.
Or I could try to install an autotransformer to isolate external disturbances ...
Thank you for your analysis and your answers.
Re: VTransfer bug ?
I'm not an electrical expert, but usually the problem turns out to be vacuum table or dust extractor. Properly grounding the machine usually helps. There was a couple of post on the forum on the subject:
viewtopic.php?p=196671#p196671
Greg K
Greg K
