How to Curve text
jberning
Model of CNC Machine: cnc shrak pro
How to Curve text
Post by jberning »
I need some input on how to curve text.
I have version 5.504 of Vcarve pro and I am trying to curve text.
I tried to use the CONVERT TEXT CURVE but it comes bact and says to select text which I did before I selected the CONVERT TEXT CURVE button.
I also tried the wrap text along a curve but the apply button is gray not black so it does not function.
If anyone can help I sure would appreciate it.
Jon
Re: How to Curve text
The Convert Text to Curve command is for making text vectors into normal vectors which isn't what you want.
The Wrap Text Along a Curve is the right command. To use it you need to create some text using the Text command and to draw a curve. You then select the text and the curve before selecting the Wrap Text command. The Apply button will then be available.
