xpro v5 to work on bulkman 3d machine with vcarve
carbuilder1959
Model of CNC Machine: puruitekeji new 4040 desktop
Post by carbuilder1959 »
trying to get xpro v5 running. when i connect usb cable from it the laptop does not reconise the device. the software says no connection. cncjs software says no comm port
Re: xpro v5 to work on bulkman 3d machine with vcarve
Have you been through the USB setup guide on the Wiki?
https://github.com/Spark-Concepts/xPro- ... /USB-Guide
carbuilder1959
tried 2 laptops and 2 usb cables and nothing. message is please connect the device. tried all usb ports on both computers
Tex_Lawrence
Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.007
Post by Tex_Lawrence »
carbuilder1959 wrote:
Mon Apr 08, 2024 7:53 am
Then, logically, the problem is not the "2 laptops and 2 usb cables". What is left that could be the problem? That's where you need to be looking for a solution.
Tex — Crooked Wood Products
Did you install the driver for the USB?
carbuilder1959
what driver. only thing left is the xpro. the 24v power is wired correctly utube clip says check twice before powering on, lights come on the controller but computer still gets nothing. bought a data usb cable just to make sure.
Tue Apr 09, 2024 8:15 am
The Wiki link I posted earlier in the thread. The first thing it says is:
If you are unable to connect to the xPRO via USB to a gcode sender, please download the CP210x USB to UART Bridge VCP Drivers
TomC
Model of CNC Machine: ultamatebee
Post by TomC »
try using cnc commander. if there is any problems they have great support Not all functions work with xpro though as it built for the nighthawk. it was the only one i could get running and be function able.
