35 yr. carpenter new to the cnc wood working.
I've a new Powermatic 2x4 machine set up ready to run. I've setup material tool and spindle speed and downloaded project to flash drive and there is no router turn on/off in the G code. it will run through all tool pathways but doesn't turn on/off router. Any thoughts out there?.
Router on/off
- Model of CNC Machine: Powermatic 2x4
Re: Router on/off
Needs to be set up within your machine control software plus the post processor you are using would need to contain the commands to turn on & off the spindle. You can edit the post processor yourself if you are able, not something I have ever had to do but there is a Vectric guide that covers it
- SteveNelson46
Re: Router on/off
Does your machine have a router or a spindle? If it has a spindle, then it should be capable of controlling the on/off and rpm speeds. It would be best to contact the manufacturer to find out how to do it. If it's a router, you may be able to control on and off if the controller has the capability but, it's doubtful it will be able to control the rpm . Again, that is a question for the manufacturer of the machine.
