I have a Powermatic 2x2 CNC in my classroom I am trying to get operational. I inherited this machine from a previous teacher, and as you may know Powermatic has basically no support.
I am trying to buy a U Disk as stated in the manual for how to transfer files. Google knows what a UDisk is, but trying to buy one yields only flash drives. If I cannot buy a U Disk, does this make my brand new never used Powermatic a useless pile?
Does anyone have a recommendation for a U Disk? Anyone have experience with a Powermatic? Please help.
Powermatic U Disk
- Model of CNC Machine: Powermatic 2x2
- AboveCreations
- Model of CNC Machine: i2r B22
Re: Powermatic U Disk
google can be your friend... from the Powermatic manual: "U disk – External data storage device that is inserted into a USB interface. Work origin (or work...."Jrasmussen wrote: ↑Wed Dec 07, 2022 3:59 amI have a Powermatic 2x2 CNC in my classroom I am trying to get operational. I inherited this machine from a previous teacher, and as you may know Powermatic has basically no support.
so basically yes, it is just a simple thumb drive. And many online stores are still selling the Powermatic 2x2. So I imagine it is still supported.
- Model of CNC Machine: Home built aluminum and steel 3 X 4 CNC
Powermatic CNC is the same machine as an Axiom of the same size...Axiom does have an active owners group.
- IslaWW
As stated above, AXIOM and Powermatic are similarly built machines painted different colors. The AXIOM"s have used various iterations of the RichAuto controller (B11, B18, B58) along with some versions of the HUST controller. Some non-US machines and the "I2R" branded versions use UCCNC controllers. You will need to know which controller you are using when you ask for support.Jrasmussen wrote: ↑Wed Dec 07, 2022 3:59 amI have a Powermatic 2x2 CNC in my classroom I am trying to get operational. I inherited this machine from a previous teacher, and as you may know Powermatic has basically no support.
I have seen posts in the past on the AXIOM forum where users have suggested downloading the Powermatic manual online as it was more comprehensive than the AXIOM version of the time.
JPW Tool Group, the parent company of Powermatic, has purchased AXIOM Precision so I would assume that the support for both brands will remain strong.
Do you have the Powermatic manual?
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
