Cut 2D has an Output direct to machine, tick box that looks like it requires a driver.
How can I use this function ?
This needs to connect to from a 64 bit window PC how does this connect ? USB ?? Interface card of some sort ?
Help please
Mick
Cut2D output
Re: Cut2D output
Depends on the machine and control software. On some Cut2D is run on the same PC as the control software and the direct output sends the file directly to the control software. Some software needs a printer driver to do that, some communicates via the registry, some via network etc etc.
