Hi all,
I have the above laser that I no longer use (purchased a 80watt stand alone system) this laser magnetically mounts on my Axiom AR6 pro and has had very little use.
If anyone is interested PM me, be aware I live in Australia so a freight cost will be involved.
Opt 7watt laser give away
- Aussie
- Model of CNC Machine: Robotics Model 8
Ron
Crafers Crafts
Crafers Crafts
- Model of CNC Machine: bravoprodigy be3030
Re: Opt 7watt laser give away
Hi aussie i live in reynella south aust and would like to have a go at laser engraving does it have a power supply and did you use it with the vectric laser add on
regards frank taylor
- Aussie
Sorry Frank its gone.frank taylor wrote: ↑Mon Jan 03, 2022 1:53 amHi aussie i live in reynella south aust and would like to have a go at laser engraving does it have a power supply and did you use it with the vectric laser add on
Ron
Crafers Crafts
Crafers Crafts
- Aussie
The laser will be on its way to a new home shortly.
Thank you for all the interest
Ron
Crafers Crafts
Crafers Crafts
- Model of CNC Machine: Laguna IQ HHC
I also have an Opt laser (6w) and I'm interested in knowing if you were using the Vectric Laser software? Did you have any problems when setting up the software to recognize the Opt laser or with the post processor? Any information would be greatly appreciated!
