Dust Management
gkas
Re: Dust Management
Post by gkas »
I may yet replace my 'sneaker net' dust collection methodology. :lol:
jimandi5000
Re: Dust Management
Post by jimandi5000 »
Here is my current dust collection (4 inch pvc) layout with gates. I've added where I think my sensors and buttons should go. After looking at this, thinking I need to increase the main run to 6 inch PVC.
Jim
jimandi5000
Re: Dust Management
Party Time!!! I got a box of parts tonight and as you can see... the servo fits! Now to build an arm and the other parts. If I do not sleep... I may have a working gate in the morning!!! :D
Jim
jimandi5000
Re: Dust Management
gkas wrote:I may yet replace my 'sneaker net' dust collection methodology. :lol:
Everything I do on this is yours if you want it.
Jim
jimandi5000
Re: Dust Management
Hello There,
I have got one working!!!
have a look.
Jim
Re: Dust Management
Post by highpockets »
That look great!!! Well designed.
jimandi5000
Re: Dust Management
Thanks, I have been looking at the electrical boxes and the cost. So, I will make my own boxes and covers. I will post some pictures when I land on a design and working prototype.
One more thing, I am thinking about posting all of the models on thingiverse or do you think there is a better site? Anyone use Thingiverse?
Jim
Re: Dust Management
Thingiverse would be a good place, use it all the time. I've been building a lot of my own boxes too.
What program are you creating your models in?
gkas
Re: Dust Management
Post by gkas »
They look great. Are you using Arduino or Raspberry Pi? Python?
This got me interested, so I bought a Raspberry Pi 4 4GB and breadboarding stuff. This looks like fun to play with. .....says the Geek with 40+ years of system programming. :lol: I'm already looking at the Pandora Pi apps for touchscreen. This is gonna cost me a mint :roll:
Re: Dust Management
LOL!!! Jim is getting both of us fired up Gerry. I've already got a nice collection of Arduino stuff, so I'm just waiting to see how this all turns out.
jimandi5000
Re: Dust Management
gkas wrote:They look great. Are you using Arduino or Raspberry Pi? Python?
I have both Arduino and Raspberry Pi. I think the Arduino would be best. If I connect the power to my lights, the Arduino will boot in a loop function. here is the list of items I am building with:
ITBEBE Gold-Plated Pass Through RJ45 Cat6 3-Prong Connectors and Cable Strain Relief 50/50 Kit for Clean, Snag-Free Patch Cords (100 Pieces Total)
Qty:1 $28.99
C2G 03859 24-Port Blank Keystone/Multimedia Patch Panel, Black
Qty:1 $18.99
CableCreation 20-Pack Cat6 / RJ45 Keystone Module Connector, White
Qty:2 $15.99
WINGONEER® Prototype Screw/Terminal Block Shield Board Kit for Arduino MEGA 2560 R3 DIY
Qty:1 $16.49
ARDUINO MEGA 2560 REV3 [A000067]
Qty:1 $38.30
Youngneer 5v Relay Module 2 Channel for Raspberry/Arduino ARM/PIC/AVR/MCU Opto-Isolated Relay Board High or Low Level Trigger
Qty:1 $9.99
SunFounder 2004 20x4 LCD Module IIC I2C Interface Adapter Blue Backlight for Arduino R3 Raspberry MEGA2560 (2 Pack)
Qty:1 $17.99
Monoprice Flexboot Cat6 Ethernet Patch Cable - Network Internet Cord - RJ45, Stranded, 550Mhz, UTP, Pure Bare Copper Wire, 24AWG, 75ft, Gray
Qty:6 $13.99
2 Pack GP2Y0A02YK0F Infrared Proximity Sensor Detect 20-150cm Distance Long Range
Qty:1 $18.88
EDGELEC 120pcs 100cm Dupont Wire Male to Female Breadboard Jumper Wires 3.9 inch 1pin-1pin 2.54mm Connector for DIY Arduino Raspberry PI 10 15 20 30 40 50 100cm Optional Multicolored Ribbon Cables
Qty:2 $19.98
BSHTU Printer Extension Cable USB 2.0 B Adapter Male to Female Connections 90 Degree Socket Right Angled Scanner Cord with Screw Panel Mount 0.5m
Qty:1 $7.99
Switching Power Supply 12V DC 3A 36W - LED Driver Universal Regulated Transformer AC 110V-220V to DC 12V, for LED Strip Lights, Radio, Computer Project
Qty:1 $10.99
Baomain Industrial Signal Round Red Warning Light Blinking Warning lamp LTE-5061 AC 110V 3W
Qty:1 $10.89
HiLetgo Analog Current Meter Sensor Module AC 0~5A Ammeter Sensor Board Based on TA12-100 for Arduino
Qty: 12 $6.99
Youngneer 5v Relay Board Raspberry Arduino Relay Module 1 Channel Opto-Isolated High or Low Level Trigger
Qty:1 $12.99
iExcell 960 Pcs M3 x 6mm / 8mm / 10mm / 12mm / 14mm / 16mm / 18mm / 20mm / 25mm / 30mm / 35mm Stainless Steel 304 Hex Socket Button Head Cap Screws Nuts Washers Hex Key Wrench Kit
Qty:1 $18.99
eBoot 6 Pack LM2596 DC to DC Buck Converter 3.0-40V to 1.5-35V Power Supply Step Down Module (6 Pack)
Qty:1 $11.25
EPBOWPT DC 12V 24V to DC 5V 10A, 5V 5A,12V 5A, 10A Power Converter Power Adapter (12/24V to 5V 3A, 12/24V to 5V 3A Converter)
Qty:1 $8.79
KEYESTUDIO 16-Channel 12-bit Servo Motor Drive Shield I2C Interface for Arduino
Qty:1 $10.50
YXQ Regulated Power Supply DC 12V 5Amp 60W Switching AC 110V/220V Transformer Converter for LED Strip Lights, CCTV, Radio, Computer Project (DC 12V 5A 60W)
Qty:1 $17.69
YXQ Regulated Power Supply DC 5V 12Amp 60W Switching AC 110V/220V Transformer Converterfor LED Strip Lights, CCTV, Radio, Computer Project (DC 5V 12A 60W)
Qty:1 $14.27
DAYKIT 10 Pairs 12V Male+Female 2.1x5.5MM DC Power Jack Plug Adapter Connector for CCTV Camera
Qty:1 $7.99
ELEGOO 3mm and 5mm Diffused and Clear Assorted LED Kit 5 Colors for Arduino (Pack of 600)
Qty:1 $11.99
ELEGOO 17 Values 1% Resistor Kit Assortment, 0 Ohm-1M Ohm (Pack of 525) RoHS Compliant for Arduino, Respberry Pi Projects
Qty:1 $10.86
Yootop 40 Pcs 2 Pole 5mm/0.2'' Pitch PCB Mount Screw Terminal Block Connector 300V 25A
Qty:1 $10.99
Yootop 50Pcs 2 Pin 5mm/0.2'' Pitch PCB Mount Screw Terminal Block Connector for Arduino
Qty:1 $8.69
HobbyPark Aluminum Alloy 24T Servo Horns Metal Steering Arms Accessories for RC Car Boat Airplane Hobby Models(10-Pack) (24T, Blue)
Qty:2 $16.99
ELEGOO 32 Pcs Double Sided PCB Board Prototype Kit for DIY Soldering with 5 Sizes Compatible with Arduino Kits
Qty:1 $10.99
Oak-Pine 2Pcs MG995 RC Servo Motor Digital Metal Gear 13kg/cm High Speed for Smart Car Robot Boat RC Helicopter Airplane Model Boat Car Robot DIY Project
Qty:6 $13.99
StarTech.com 3 ft. (0.9 m) Right Angle USB to Mini USB Cable - USB 2.0 A to Right Angle Mini B - Black - Mini USB Cable (USB2HABM3RA)
In Stock
Free Shipping for Prime Members
Qty:1 $5.83
POWERTEC 70135 4-Inch Aluminum Blast Gate for Dust Collector/Vacuum Fittings
Qty:6 $11.87
POWERTEC 70165 Aluminum Blast Gate, 3
Qty:6 $10.64
Jim
Re: Dust Management
Jim, just a thought, should there be some consideration for EMI?
jimandi5000
Re: Dust Management
highpockets wrote:Jim, just a thought, should there be some consideration for EMI?
The CAT6e should be ok with Electromagnetic interference. I just tested a 75ft cable ran throughout my shop looping around running machines, no issues with gate open and closing.
Jim
WNC_Ed
Re: Dust Management
Post by WNC_Ed »
Great project - watching with interest!
Just a thought on your pipe diagram. Ideally the Router table, Jointer, CNC, and lathe should all have their own port from the main trunk line.
Sanders and saws should be fine "ganged up" on a branch since they produce mostly fine dust.
Again, just a thought.
Maker of sawdust
jimandi5000
Re: Dust Management
WNC_Ed wrote:
Wed Feb 19, 2020 2:51 pm
Hi Ed,
That is a great suggestion, I am thinking I will repipe the system after I get the auto gates working.
Jim
