Hi, im new and i cant seem to get this toolpath to work. instead of tracing a bitmap, i used the polylines vectric tool to create this design. When i calculated the toolpath, only the outline was pathed, not the interior. ive checked for open vectors and changed starting points but to no avail. Any ideas? thanks
polylines vectric toolpath issue
Re: polylines vectric toolpath issue
Did you perhaps use the profile toolpath instead of the pocket toolpath? Profile will run on, or on either side of the vector, depending on how you set it up. Pocket will carve the interior (at the depth you specify) from the inside of the vector.
- adze_cnc
My guess would be the diameter of the cutter is greater than the slots' widths.
- sharkcutup
Use a Smaller Diameter Router Bit
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- Model of CNC Machine: LongMill 30x30
Great that you made your own vectors!!!
Do you want a v-carve or pocket?
