Hi
I mill normaly 2mm Aluminium Plates. I use a 3mm router bit and use two passes.
if i use the "Use approach" function, it is only used for the first run when i use "single last pass" at same time.
When i dont use the "single last pass" than works "Use approach" on both passes.
Is this a bug?? I want combine "Use approach" and "single last pass" but i dont know how it works.
Jürgen
Use approach
Re: Use approach
I always create two toolpaths so I have more control over the last pass. I then use the Merge Toolpaths to create one toolpath to send to the machine so that all the parts are cut in the correct sequence.
Doing it that way gives you far more control as you can set different RPM, feed rates, ramps, leads etc.
Re: Use approach
+1 on what Adrian has just said
Funny enough I have been doing it that way since reading a similar post Adrian made a few years ago
- Model of CNC Machine: Fenja
Re: Use approach
Ok thx Adrian,
I try it and yes this works.
I think its one Way to make this. Thx. But why it doesn´t work at once??
Why i must take this Way
Ok thx for u Help
Jürgen
Ok thx for u Help
Jürgen
Re: Use approach
I assume it's because the last pass is a very thin cut used to clean up the edge from any witness marks from plunging or ramping so it was never designed to use a ramp.
