Re: Vacuum Jig with 5 areas of vacuum
Posted: Sun Dec 04, 2022 7:11 pm
Made a 24" by 24" Vcarve file for a Vacuum Jig with just one gasket that will handle something flat 24 by 24. My plan is to carve this out this week in some PVC trim board from the local box store. I will glue up 4 pieces of this pvc siding trim to get a 24" wide piece. Then carve it out using the pod file that has all of my vacuum pods in the one file. This includes the toolpaths using layers and sheets.
What are you going to use as an adhesive? Just be aware that certain types of plastic need more specialist adhesives & PVC is quite a general term so, not sure what you are using for this. Where ever you are buying may be able to help with what to use
Did you find out if the PVC you are using is porous at all? Just be aware that if it is then the larger you make the vacuum hold down the lower the vacuum you will be able to maintain. The good news is that with a sheet at 24 x 24 you won't require a large vacuum to hold it down
