Bit selection conundrum
- Model of CNC Machine: Custom Openbuilds
I am looking to do a two sided lettered cutout for a beer tap pull for a friend. Essentially a vertical lettering that will be mirrored on the alternate side and cut out on the contours of the letters. Trying to figure out the best bit / cut type to do the letters. I assume I would use an end mill to do the final cut out. Should I do it as a Vcarve or pocket? If pocket, it seems to need a 1/16” mill to ensure the letter detail. If I go to 1/8” Varve seems to show that it will not cut the detail and previews what looks like a bunch of blobs. ?? If I do it as a Vcarve will a 60 degree work ?
Re: Bit selection conundrum
Perhaps some images of what you have already done might help people visualize what you are trying to accomplish? Even if they are what you might consider to be "failures".
