Box Creator bottom joints?
Does anyone know how to eliminate the bottom box joints besides by node editing? Also why doesn't the height create correctly when it is made on the drawings? I created 5.5" in the dialog box with a 1/8" End mill, but the end of the finger joint was measured 5.25".
Re: Box Creator bottom joints?
If you want to create custom box shapes it's far simpler to create your own than trying to modify the output of that gadget. If you want to remove parts then you have to node edit and make sure you're editing the correct vector as it creates two.
Often asked question; perhaps some answers can be found at these other threads:
2021-12-20
2021-12-29
2022-02-23
2021-12-20
2021-12-29
2022-02-23
