VCarvePro 11.010
Is there a way to have one sheet a single-sided job and another sheet a two-sided job? It seems that this decision must be made in "job setup", which relates to all the sheets. Correct?
Double sided job using sheets
- dealguy11
Re: Double sided job using sheets
Correct. However, just because you choose 2-sided doesn't mean you have to put something on both sides of the sheet.
Steve Godding
- Model of CNC Machine: Sienci Long Mill
Understood. Tks much
