Good day all, I was wondering if there is a tool in place that will allow us to apply a common cut tool path to a project. For example, if you have a job that needs 100 four by four inch pieces, you can nest them 1/4" apart from one another and then run your bit down the rows and then columns for quicker finishing times. At the moment, I draw a line then another 4.125" (the size of the object plus half the diameter of the tool) and then another line and replicate (copy/paste helps) to create a grid then I have to align that grid centered between the parts. Is there a quicker way here?
Thank you
common cuts tool?
- Tex_Lawrence
Re: common cuts tool?
This is the duplicate post.
Tex — Crooked Wood Products
See: viewtopic.php?f=3&t=39265&sid=be1bc6a59 ... 84e7a04ffd for the other post.
