Hi Ya'll,
I have created a simple 2 inch grid line pattern that you can use to add grids to your spoil board. I used Vcarve Pro but it should also work with Vcarve Desktop.
The toolpath is set up for a 60 degree vbit, there are 2 toolpaths, one for the vertical and one for horizontal lines
Hope this helps anyone that is looking for grids
David
Shapeoko XXL Spoil Board Grid Lines
Re: Shapeoko XXL Spoil Board Grid Lines
Update:
The Y distance was only set to 22 inches as this was the height or width of my XL spoil board which I have placed on top of my now new XXL main spoil board. You can increase the distance of the Y grid lines as needed.
David
David
New File has been added, it covers the 32x x 40y inch spoil board size for the Shapeoko XXL. Using a 60 degree vbit and no flat depth.
I removed the first attachment as it had some issues so it was deleted and I started over.
Hope this is helpful
Regards,
David...
Regards,
David...
- Grid lines 32x x 40y at 2 inch.zip
- (65.6 KiB) Downloaded 145 times
- Tex_Lawrence
- Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 11.554
David, now that you have it worked out, you should also post on the forum associated with the Shapeoko. I'm sure many more will appreciate it there, too. +1
(I've posted the name of the manufacturer of the Shapeoko before and got it censored.)
Tex — Crooked Wood Products
