errors in bitmap to vector videos
adze_cnc
Post by adze_cnc »
I've watched a number of "How to convert bitmap to vectors" videos lately and have been non-plussed. The presenters mean well but they commit two "sins" when it comes to the image (a.k.a. raster or bitmap) files:
  1. scale-up and / or rotate image prior to converting it to vectors
  2. saving a smaller-sized image displayed by Google image search (GIS) as the preview of the larger-sized image found on the linked website
The problem with number 1 is two-fold:
  • scaling and / or rotating distorts the bitmap and that loss of fidelity transfers to the resulting vectors
  • unlike Hollywood in which scaling up a bitmap makes it "more in focus" scaling digitally "smears" the image. For example if you have a 10x10 pixel image and each pixel is a different colour (100 in total) which you scale up to 20x20 you will still only have 100 colours but each one of them will be represented by a 2x2 square instead a 1x1 square.
It's far better to create vectors from a small file and scale-up and rotate those vectors. Vectors are made to be transformed without any loss in fidelity.
The problem with number 2 is that the image is not as large as it could be. In one video I watched recently the image at the linked-to site was 1880 pixels wide but the one the presenter saved from the GIS preview was 483 wide. Yet he was sure that he was saving the higher-resolution version.
Sample images to make two points clear:
Small image 92x99
Small image 92x99
Small image digitally zoomed by software to 276x297 (note the smeared unfocused appearance caused by replacing each 1x1 pixel with a 3x3 block)
Image optically zoomed to 276x297 (same size as previous but much sharper as the pixels haven't been tripled)
In summary:
  • don't scale / rotate images; scale or rotate vectors instead
  • take the time to get the best resolution image you can (go to a linked website or scan at a higher pixel per unit of measure)
  • bonus: avoid jpeg if you can (don't save to this format when scanning)
PS. Vectric's own tutorial video violates point number 1 above.
Re: errors in bitmap to vector videos
Post by highpockets »
Good tips, thanks for sharing....
scotttarnor
Model of CNC Machine: Piranha XL , Shark HD520
Post by scotttarnor »
Thank You for the tips!
Scott T
@scottscnc
