Any option for “clearing bit” for profile cutting?
I’m relatively new to Vectric. I’m using Vcarve Pro. I’ve done a few carves on my woodworking CNC but curious to know if there is any option for profile cutting similar to pocket carving where you can start with a larger bit and use a smaller bit just for inside corners? Is there anyway to configure this?
Re: Any option for “clearing bit” for profile cutting?
Short answer: no
Slightly longer answer: FixitMike posted a solution to this sort of question here: viewtopic.php?p=195135#p195135
- FixitMike
It can be done, but is somewhat complex. This description is for using a 3/8" profiling bit and a 1/16" finishing bit. The numbers used are to show the method only.
1. Add a dummy V-bit with a 0.1 degree included angle in the tool data base. (That's right: 0.1 degrees.)
2. Offset the profile outwards .400". (A bit more than the profiling bit diameter.)
3. Select both the original profile and the offset. Set up a VCarve toolpath:
- A. Flat depth equal to material thickness (Or possibly a tad more.)
- B. Use the dummy V-bit, and a 1/16, and 3/8" clearance bits.
- C. Calculate the toolpath. Use only the VCarve toolpath for the 1/16" bit.
4. Calculate the Profile toolpath for the 3/8" bit. Include tabs if desired.
5. Cut the piece out using the profile toolpath and the 1/16" toolpath from the VCarve calculation.
- FixitMike
And, a similar method using a Pocket toolpath. This also uses 1/16" and 3/8" bits.
1. Add a dummy end mill with a .001" diameter to the tool data base. (That's right: 0.001" diameter.)
3. Select both the original profile and the offset. Calculate a Pocket toolpath:
- B. Use the dummy .001" dia. end mill, and 1/16, and 3/8" clearance bits.
- C. Calculate the toolpath. You will use only the Pocket toolpath for the 1/16" bit. ( Probably "Pocket 1 [Clear 2]".)
4. Calculate the Profile toolpath. Use a 3/8" bit. Include tabs if desired.
5. Cut the piece out using the Profile toolpath and the 1/16" toolpath from the Pocket toolpath calculation.
Thanks for the feedback guys. A few things for me to try.
I wonder if that is something they would ever consider adding in the future. I'm surprised it has never been recommended before.
Thanks again
Thanks again
Depends how many (if any) people have asked for it directly to Vectric. I can only remember it coming up once or twice in all the years I've been on the forum. I can think of many other things that come up on a monthly basis that aren't in the software (yet) so it's all a question of priorities with a small company I would guess.
