spiral - in toolpath
I want to plane a large surface by starting at the outside perimeter and making conventional cuts with 40% of the tool diameter as I spiral in to the center. Or I would like to go up one outside edge with a conventional cut, off the edge and then over and down the opposite edge with a conventional cut, moving in each time until I reach center. Vcarve seems to only have paths that let me spiral out from the middle or go up and back on the same side which forces me to do one of 2 things I dont want, namely 1) to start planing by putting the entire 2 1/2 inch cutter down on the board or 2) to make alternating conventional and climb cuts.
Is there a way around this?
Re: spiral - in toolpath
You could create a rectangular spiral vector and use that for a profile toolpath either starting it off the edge or specifying a lead-in ramp at the beginning of the toolpath.
- mrmfwilson
- Model of CNC Machine: Legacy Arty 36
You could just draw vectors where you want the tool center to be. Make each vector start point alternate ends. Then use a profile path and the Vector selection order to control the order from one side to another. Maybe someday we will get to have choice of how to cut a pocket. From the inside or outside. Seems simple but I haven’t tried to write the gadget so I don’t know how hard it would be.
Mr. Wilson
CenterLine Designs
Facebook - Centerline Designs
CenterLine Designs
- SteveNelson46
I usually use a pocket toolpath to surface my SB but I have experimented with profile toolpaths. Here's a spiral I sometimes use for my 24" X 36" spoilboard. It uses a 1.25 EM with a 50% step over. I drew the spiral using the Corel Draw "Contour" tool and then cut and reconnected the corners in Aspire.
- Spiral SB resurface-1.25EM .02 DOC.crv
- (30.5 KiB) Downloaded 117 times
What problem are you trying to solve with the spiral toolpath vs the standard toolpaths? i.e. why does it matter?
- TReischl
Hmmm, I don't know what problem he is trying to solve, but I can share why I would like to see a spiral in option:
First off, I work from a vise(s) quite often. Secondly, most times the stock is already cut to finish width and length. To flatten the surface I would like to spiral in with a climb cut to avoid splintering out the edges.
Even when I am just flattening stock I am not keen about the splintering (I work a lot in soft wood) which happens on the edge and if I use a raster routine produces nasty strings which can clog up the dust collector in the most inconvenient spot imaginable.
Is it a big deal for me? Nah, not really. I have become good at creating the rectangular spirals I need over in the design software I use.
But it would be one of those "nice things to have".
- jfederer
- Model of CNC Machine: CanCam D23M
I agree with Ted, it would be a "nice to have". I flattened both the top and bottom of my current project, the base for a fountain sculpture. The edge splintering on the top didn't matter because it was followed up with a drive rail 3D wall. But the bottom does have noticeable splintering, and this is with end-grain Maple. An inward spiral would have prevented this.
Joe Federer
www.federer.ca
www.federer.ca
Thanks for the replies
We are flattening large slabs for tabletops.The reason for wanting these paths is to avoid the two things I pointed out in my post. Putting the full diameter of a large bit down on the center of a surface may be fine for planing a soft spoilboard but you risk a burn or more catastrophic result on hard maple. You don't want to be doing any climb cutting. Working back and forth with a conventional cut on opposite sides with 40% of the diameter will leave a much nicer finish on the grain.
Since our tops are all different sizes, the approach we have opted for is to write an Excel spreadsheet which generates the g-code for any sized tabletop we input. Maybe someday this can be done in Vcarve.
If you are capable of writing a spreadsheet that generates g-code then have you considered creating a Vectric gadget to do what you want?
I don’t know how to write gadgets but I can look into it. After 32 years as an actuary I can make a spreadsheet that will take out the trash
