drag bit question
kdwiz57
Model of CNC Machine: home built w/ mach3
drag bit question
Post by kdwiz57 »
I am new to using a drag bit so here is the question. I did an image that was done using the fill option. In areas the was filled the drag bit almost looked like it "tore" material on some passes so it left a very ratty. uneven finish. I used a .001 step over rate with a .028 down pressure on the bit. Should I be using a larger step over? Should I be blowing compressed air on the tip of the bit to reduce any build up while the tool is dragging. I did an image that was outlined with a .03 down pressure and it looked fine.
I am open to suggestions and any tips you might offer.
adze_cnc
Re: drag bit question
Post by adze_cnc »
This is a duplicate post of
https://forum.vectric.com/viewtopic.php?f=3&t=37261
(actually the wording does differ a little).
You don’t specify the material so perhaps “tearing” is to be expected?
rtibbs
Model of CNC Machine: Shopbot desktop
Post by rtibbs »
What type of acrylic are you using. Cast is the preferred acrylic material. Gives good clean lines as opposed to some of the other “Softer” grades
Aussie
Model of CNC Machine: Robotics Model 8
Post by Aussie »
Are you using a diamond drag bit or a 90 deg V Bit?
Ron
Crafers Crafts
Xxray
Post by Xxray »
Should probably be marked "solved" since op can't be bothered to post back with any details required to help him/her
Doug
