Hi all,
I'm using VCarve desktop 10.5 with a Next Wave Pahana XL CNC with a 12 X 24 rectangular work surface. As you would look straight down onto the work surface from the side of the machine it cuts the part out from "left to right".
When I create a file to cut I need to orient the drawing "north/south" in VCarve in order for the CNC to cut it in the right direction.
I know it's a small annoyance to draw the file out left to right in VCarve and then remember to turn it 90 degrees before saving the .tap file.
If I forget to do that the gantry goes all the way to the stops trying to side in an attempt to get to the first cutting spot.
So, the question is am I missing a "switch" in VCarve that tells the CNC, Oh BTW cut it like this not how it looked on the screen ?
Or is it just WYSYWIG and I just continue as I've been doing.
Kevin
Tool path orientation?
- TReischl
Re: Tool path orientation?
This subject has been beaten to a pulp in several threads. You might want to do a search or maybe someone with better searching skills than I can point you in the right direction.
Well after finally getting the right keywords I found a couple of those threads.
Yeah, no fix just turn it 90 degrees
In a way there is a fix. The next time you need a computer upgrade, or if you feel that want to add a second monitor to your computer setup, consider getting a monitor that can rotate to "portrait mode".
I have that but when doing signs and such it's much easier the create the files as you would read it. Doing that vertically is just painful.
or swap your X and Y cablesIn a way there is a fix.
or change the post-processor to swap X and Y
or get used to the XY orientation and, depending on how your material is arranged, rotate everything before you toolpath and save the output
- TReischl
If I were a betting man I would lay dollars to donuts that Vectric is never going to offer that option.
And there is a reason. The standard cartesian coordinate system is X horizontal, plus to the right.
Solidworks, for whatever perverse reason, thinks that the Y axis is "up". I am constantly having to rotate models exported from it by 90 degrees to get Z up.
You could tell that the people who created the Solidworks model rendering engine were different than those who created the Solidworks modelling engine. Objects' shadows would be cast "on the wall" and not "on the floor"—they knew which way Z was...
- TReischl
There was a time when some developers thought that Z axis should go into the screen, maybe they were having a divinity complex, as if they were looking down on the whole world.
