I posted this on another forum so I'm sorry if you are reading it twice.
I know there are many ways to solve a problem. Maybe others will add their solutions?
I have always wanted an easy way to pick the right roundover tool. Often the customer says I want this edge on a project. Just like the sample piece they bring with them. Or, I just don't remember what I had used previously. So, then I have to guess which tool to use. I made a simple template for something to use to try and measure an existing radius. Rather than grabbing a sharp tool off the wall. Or in the case of larger diameters pulling out circular objects around the shop.
This is roughly a ten inch diameter piece of plywood. I planned to cut from plastic, but this test piece is probably going to work fine.
If you like the idea, download the file here.
Radius Guide
- Model of CNC Machine: CAMaster Stinger II
Radius Guide
- RadiusGuide.crv
- (794.5 KiB) Downloaded 126 times
Charlie
Aspire, CAMaster Stinger II
- Tex_Lawrence
Re: Radius Guide
Charlie, that's a good tool. The only thing I can think of are edges that aren't a single or constant radius may throw a kink in the measurement. You may not have run into anything like that.
You might want to add the other side to that story and build the tool that does convex curves.
Tex — Crooked Wood Products
- Model of CNC Machine: Homemade
Radius Guide
swell idea. thanks.
- Model of CNC Machine: Multicam
Re: Radius Guide
A very wonderful idea. Is there any chance of the file being backward compatible to VCarve Pro 9.5?
Thanks, Robert
Thanks, Robert
- Model of CNC Machine: Sienci Long Mill
Re: Radius Guide
As Charlie put it here for anyone to download and use, I trust that he won't mind me posting it as a dxf, which Robert can import into his version of VC.
Re: Radius Guide
I appreciate the file, Thanks wilkigr
