Hi - I have VCarve Desktop and need to start making guitar neck and fret boards. I'm sure Aspire would do the trick but the price tag is in the way.
Can I create Guitar necks with Pro or 3D?
Tom
Making Guitar Neck with Vcarve Pro
- Model of CNC Machine: Shark II
Re: Making Guitar Neck with Vcarve Pro
You cannot create a guitar neck in VCarve, but you can import an STL file created in another program and use VCarve to generate the toolpath files to cut it on your machine.
Use your favorite search engine to search for guitar neck STL
Another option is to get a scan done of a neck you have already created. I made a banjo neck and had Brady Watson of IBILD.COM do the scanning. I was very satisfied with the results.
Tom,
I hope you do mind me posting here.....
I am too trying to learn to do a guitar neck. I only have Vcarve Pro and really could use some help to figure out how to bring in a 3d model of a neck and then work out the tool paths.
I have found some examples for Aspire but I don't have the extra $1300 for an upgrade.
Not sure if you are aware of this but there is http://www.3dcncguitars.com/Home/ where you can buy such files in Vcarve Pro and there are example toopaths,etc.
I just emailed with Alex and asking him a bunch of questions. The guitar I am looking at he charges $75 for the Vcarve Pro files with the example toolpaths. I am most likely going to buy it when he and I can connect again.
- gkas
Look at the 3D Assemble & 3D Toolpaths. https://www.vectric.com/support/tutoria ... rollToMenu
If you're new to Vcarve, you may want to start with some of the basic tutorials. Also, you may need the 2-sided machining tutorials.
- Alex Navarro
- Model of CNC Machine: 3 axis
If you do not care to need sand a little more the wood to modeling it better with you luthier skills you can do the shape neck on VCarve like I show in this video.
This video is only an idea how you can do it, but each model will give will different challengers
https://youtu.be/r7SL0x29B4w
Alex Navarro
- Model of CNC Machine: Home made CNC
Hi Guys, Happy 2024, I hope the New Year brings better projects and new ideas.
I have a question that hopefully, can be answered.
I would be using V-Carve Pro 11.554 version and I want to carve a guitar neck, I have a file imported. Once the neck has finished carving I want it to be nice and clean without any slight edges along the two sides of the neck when doing the profile on the back of the neck.
When the tool cuts along the neck following the curved profile, I have seen where some people end up with what seem to be unfinished edges at the bottom of the curved profile of the rear of the neck and I want to avoid that. Is there a way and or tool path to avoid that happening so that the finish of the neck is nice and clean? OOps, more than one question.
Regards
Regards
