Dear Board.............
Can anybody refer me to a service that is able to convert the attached .crv file to a .dxf
or if anyone familiar to a software that can do so? Thanks
Jerry
.crv to .dxf
.crv to .dxf
- Vectors Horse 26june20.crv
- (102.5 KiB) Downloaded 468 times
- scottp55
Re: .crv to .dxf
Simply select all vectors(G roup if you want),then under File tab....Export as any format listed.
Likewise, use the Import, to bring it into a new project.
scottI've learned my lesson well. You can't please everyone,so you have to please yourself
- scottp55
Re: .crv to .dxf
No problem:)
You should have seen how much help I needed when I first started!
Re: .crv to .dxf
Thanks again.
Second question please?
Are you familiar with a laser cutting service that can cut this out of 16 gauge steel?
Jerry
Jerry
Re: .crv to .dxf
There are a number of companies that will laser cut your .dxf files. A couple are oshcuts, sendcutssend or protolabs are just a few.
Their prices in many cases are cheaper than some of the local vendors. (At least for me.)
Google is your friend.
Re: .crv to .dxf
Perfect.......thanks again
