I usually run the V-bit tool path at least twice to clean it up. Is there any advantage to reversing the direction in the second pass? Any reasons not to?
V bit carving
V bit carving
Mark
Pioneer, CA
Pioneer, CA
Re: V bit carving
Almost all toolpaths can be run with a v-bit. Are specifically referring to the "V-Carve / engraving" toolpath?
Re: V bit carving
Actually, not specifically. I also use a V60 bit for chamfering raised letters and borders, using the profile tool path.
Mark
Pioneer, CA
Pioneer, CA
- Model of CNC Machine: laguna swift 4x4
Re: V bit carving
I often run a second toolpath for clean up, and in my opinion if you have the time to do
this it is well worth it. I would think most people would not simply because of the time
to do this.
As far as reverse direction for the second pass I don't see why not. I have not tried it
but think it would be interesting to see the results. I am usually looking for the best result I
can achieve and not concerned about the time it takes to get there.
to do this.
