I only used two sided tape on my projects in the beginning, but soon realized that it was called a spoilboard for a reason. I know use corner jigs cut from outdoor plywood with a small curve in the center to hold old my projects. I also use self drilling screws to easily lock the jigs in place.
On large projects I use a first cut of 1mm to outline all my projects so that I know where to safely put the self drilling screws.
The jigs are double functions as it was designed to also help me in clamping pieces square. I have added the project file below.
Here is a link to a sample screw box. Buy them in quantity since they have a very large head, I can also use them force the project piece onto the spoilboard nice and flat.
https://www.menards.com/main/hardware/f ... 699&ipos=2
For the clamps, notice there is an outside piece and an inside piece.
Avoiding Machine Gotchya's
- Model of CNC Machine: AvidCNC
Re: Avoiding Machine Gotchya's
- Corner Clamps V2.crv3d
- (2.15 MiB) Downloaded 151 times
- Rut Row
- Model of CNC Machine: Next Wave CNC Shark HD520 w/ 3hp spindle
could you convert the attachment to a standard .crv? vs 3D
- Model of CNC Machine: eBay special China 3040
From my experiences, people tend to run their machines too SLOW, not too fast.
It's almost as if there's a contest of who can take the longest time to do a relief cut. "here it is, after 36 hours cutting" type stuff.
I had a few moments so I manually redrew these. Maximum size of cutter that can cut these is 3/8" (9mm).
- corner clamps v2 (srh) inch.crv
- (21.5 KiB) Downloaded 89 times
- corner clamps v2 (srh) MM.crv
- (21.5 KiB) Downloaded 62 times
