Box or Frame Clamp
Tailmaker
Box or Frame Clamp
Post by Tailmaker »
I have been making several boxes, drawers and similar things with finger joints and dovetail joints and proper clamping was always a challenge. Normal clamps do work but for even application of pressure along the joints a large number of clamps may be needed and additional measures to keep everything square as well. I tried also frame clamps with threaded rods but found them cumbersome. Sometimes the glue starts setting while I am tying to align all the parts.
So, I came up with my own adjustable box clamps that can be pre-adjusted when dry-fitting, tightened quickly (I use a battery powered impact driver) and keep everything square. I did not do research if that is anything already invented, but so far I have not seen it yet. Thanks to Dan P. who initiated this idea with a fixed size clamp.
If somebody is interested, the V-Carve file for the plywood parts can be downloaded here
AlbertaClipper
Re: Box or Frame Clamp
Post by AlbertaClipper »
Very nice. I'm sure it will come in handy. Thanks for the file.
Ms Wolffie
Post by Ms Wolffie »
Just a question:
Why are the clamps serrated?
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
kaartman
Post by kaartman »
Thank you for sharing, truly a cool clamping method!
Phil
Post by Phil »
I like your clamp, nice job. I'm figuring that the serrations reduce slippage.
Phil
Jozua
Model of CNC Machine: EZ-Router
Post by Jozua »
Thank you for sharing the file. It is very innovative.
I am going to cut mine out of 12 mm Corian. If some parts are a little flimsy, I will cut doubles for those and make a glue-up to 24 mm
I have about 1,500 kg of Corian off-cuts in various colours and most pieces are larger than the material size required for cutting this file. I will collect another 1,500 kg of Corian off-cuts later in December. The best part is that it is all for free.
Joz
Tailmaker
Post by Tailmaker »
Jozua wrote:Thank you for sharing the file. It is very innovative.
Joz
Joz, sounds like a plan. Since you have tons of it (envious here) you probably know how to deal with it. My only concern would be that Corian is kind of brittle. Not sure how much clamping force you could apply before it cracks.
Tailmaker
Post by Tailmaker »
Phil wrote:I like your clamp, nice job. I'm figuring that the serrations reduce slippage.
Phil
Yes, in a way. The original design had cross-drilled bolt heads with a steel dowel that registered with the serration. That worked but is more complicated then necessary and does not really have a benefit.
The published design uses smaller carriage bolts that don't need to be modified with their heads in a small sliding block. But there are other modifications possible.
Jozua
Post by Jozua »
Tailmaker wrote:My only concern would be that Corian is kind of brittle. Not sure how much clamping force you could apply before it cracks.
Actually, you have a point for consideration.
On the other hand how much clamping pressure does one really need for a small box?
It is really not necessary to clamp the “living daylights” out of it.
I will see how it performs.
Joz
kzeyus
Post by kzeyus »
Interesting idea! Thanks!
Ken Zey
Rogers, AR
http://www.CedarSlabSigns.com
http://www.lookoutmercantile.com
Shopbot PRS Alpha 72x144
gordread
Model of CNC Machine: CNC Professor HDX
Post by gordread »
Great idea. Thanks for the files.
Gordon
GraClay
Post by GraClay »
That is a terrific idea and thanks from me too for the file.
GC
PaulRowntree
Post by PaulRowntree »
Thank you!
Paul Rowntree
bill565
Model of CNC Machine: One of those "Practical"4x4s
Post by bill565 »
Thanks for the file, and cant wait to try it out.
Bill
Save the Whales, Collect the Whole Set
http://www.bcnc-fab.com
pops1964
Model of CNC Machine: shopbot buddy bt 32
Post by pops1964 »
Thanks for the file , I like making box's maybe this will be the one to retire all the box clamping stuff I use . Thanks pop's :mrgreen:
POPS1964
SHOPBOT Buddy BT-32
