Hole size change
knowlzy0791
Model of CNC Machine: PAE 110SD Series/Mach3 Software
Hole size change
Post by knowlzy0791 »
Hey there everybody!
Got a sheet all drawn up with 240 .25" holes in it.
Now the holes need to be .1875"
Is there a way to edit all of the holes sizes? Every-time i select them and try to resize it just shrinks the square that they are in.
thanks!
CharlieP
Vectric Staff
Model of CNC Machine: Saimsmart CNC
Re: Hole size change
Post by CharlieP »
Hi there!
If you select all of the holes and use the Offset vector tool going inwards to a distance of 0.03125, you should get the result you want!
I hope this helps!
knowlzy0791
CharlieP wrote:Hi there!
I hope this helps!
Talk about handy! I have spent so much time selecting holes individually! Thanks a bunch!
CharlieP
Vectric Staff
Post by CharlieP »
No Problem! Glad to help :)
knowlzy0791
CharlieP wrote:No Problem! Glad to help :)
I think that is the first time something has been easier in Vcarve then it was in AutoCAD. I can't figure out how to do multiples in that program to save my life
scottp55
Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP11.5
Post by scottp55 »
There is the circle resize gadget too! GREAT tool as you can select an entire area, select a circle size, enter a tolerance, and then resize all to your new dimension. One minor drawback is you can't undo. You have to do it again and select that NEW dimension and redo it.
FixitMike
Post by FixitMike »
Another hint: If you offset to make new holes, put the new holes on another layer. Then you can turn the first layer off when you make your toolpath. Or just delete it to get rid of the original holes.
Using the vector selector tool on the edit menu can be great for selecting multiple circles as well.
Like Scott I use the Circle resize gadget as it does it all in one.
Mark
Vectric Staff
Post by Mark »
Hello knowlzy0791,
If you are simply drilling the holes with a .1875 drill instead of using a .25 drill,
as opposed to boring them out with a pocket toolpath.
You would not need to alter anything on the design.
The drill toolpath will drill in the center of the selected vectors (circles).
You would just need to reselect the smaller drill for the drill toolpath on the original 0.25 circles.
I hope that this helps.
thephridge
Model of CNC Machine: Home built Gekko 540 driver. 4' 8' bed
Post by thephridge »
Hi, We used the "offset vectors" tool to increase the size of some holes yesterday and now we can get the holes to be the original size. I can't figure out if the offset vector tool is somehow still active or what? We deleted the first set of files and started over. The holes in the VCarve set up are 0.44 and they are coming out 0.47. Does anyone know a solution?
David
thephridge wrote:
Wed Aug 10, 2022 4:36 pm
David
It's best not to create multiple posts for the same issue as it just confuses the replies.
viewtopic.php?f=2&t=40175
thephridge
Noted. Thank you.
