Question on cutting connected letters
Jhightower87
Model of CNC Machine: Laguna Swift
Post by Jhightower87 »
Hello! I frequently cut numbers out from solid maple, cherry, and walnut. I have someone wanting some numbers cut that are connected, so instead of the number 12 being two separate numbers, they would be together. I am attaching a photo for reference. I am trying to figure out how to set up my toolpaths so that I can accomplish this. Can’t figure it out! Help please!
Re: Question on cutting connected letters
Post by highpockets »
Something like this?
Post by Rcnewcomb »
Or this?
TOgether12.crv
(195 KiB) Downloaded 8 times
10 fingers in, 10 fingers out
another good day in the shop
Jhightower87
Rcnewcomb wrote:
Sun Jun 14, 2020 11:41 pm
Or this?
Something like the 1 and the 2 connected with a bar would work. How can I go about achieving it?
Post by adze_cnc »
You’ll need 3 vectors and 2 toolpaths:
Vectors: one each for the “1” and “2”. One having the “1” & “2” connected by a bar.
Toolpaths: one profile toolpath that cuts part-way down around the “1” and “2” individual vectors (see highpocket’s image). One that cuts all the way though the material around the composite “1” and “2” connected by a bar vector,
Jhightower87
adze_cnc wrote:
Mon Jun 29, 2020 10:35 pm
My confusion comes is on the second part--cutting all the way through. How can I tell the program to cut the letters out around the bar without separating them from it? It seems like I would have to cut off the portion of the number toolpath where the bar is to keep the file from cutting that part. Or is there any easier way?
Here's how I did it...
I created 2 layers, "Numbers" & "Bar"
On Numbers I put "12" with a box around the numbers.
On Bar I copied the numbers, added the bar, converted the numbers to vectors and used the Trim tool to combine the numbers and bar into one closed vector.
I created a Pocket Toolpath using the vectors from the Numbers layer setting the depth of the pocket to .0625" to set the thickness of the bar. You can get creative with the box vector to speed things up.
Then I created a Profile Toolpath using the vectors from the Bar layer to cutout everything out.
Post by Rcnewcomb »
My approach was similar to Johns.
Enter "1 2" in a text box
Draw a rectangle that overlaps the 1 and the 2.
Convert the text to vectors.
Copy everything to a new layer.
Use the scissors tool to trim away the text and rectangle vector so you are left with the connector that follows the shape of the text.
Use these vectors for the pocket toolpath that is 1/2 the thickness of your material.
Go back to the original layer.
Use the scissors tool to trim away sections of the rectangle and the text where the bar connects
Use these vectors for the Cutout toolpath.
Post by Rcnewcomb »
Here is the CRV file
Connected12.crv
(312 KiB) Downloaded 5 times
What Randall said.... :lol: :lol: :lol:
Post by adze_cnc »
Jhightower87 wrote:
Mon Jun 29, 2020 11:48 pm
By having the bar connect the two numbers so that the composite is one vector. The profile can then be cut around that.
Imagine you have two vertical rectangles representing two number ones. Connecting a bar to those and you would have a shape like the letter “H”. This can be done by drawing two horizontal lines between the two ones and then trimming away those parts of the "ones" that you don’t need.
Creep, crawl, walk, run.
Jhightower87
You have all been very helpful! Thank you all!
