Hex jewlery box
- SteveNelson46
Hex jewlery box
Just a simple one day project. Every time I make one someone else wants one also. I think I've made 10 or 12 so far and I try to make each one a little different. This one has a different set of roses and I changed the font on the name. Both are on a textured background.
Re: Hex jewlery box
I like it, nice jewlery box.
Gary
Gary
- scotttarnor
- Model of CNC Machine: CAMaster Stinger SR-23
Re: Hex jewlery box
Very nice indeed!!
- SteveNelson46
- TomWS
- Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Re: Hex jewlery box
I like the Hex shape of the box and the smooth but simple lines of it. What bit(s) did you use to carve it?
- SteveNelson46
Re: Hex jewlery box
The base/bottom and the underside of the lid were created with 2D toolpaths. On the inside pocket of the lid I used an Amana 1.125" bowl and tray bit and for the rim to fit inside the bottom I used a .5" DC end mill. The top of the lid was modeled in Aspire and I used a finish toolpath with a 1/16" tapered ballnose and a 1/4" EM for the cutout. The texture is just one of the standard textures that comes with Aspire.
- SteveNelson46
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Re: Hex jewlery box
Beautiful job Steve. Are you cutting the box from one solid piece of wood
Thank You
Doug
Doug
- SteveNelson46
Re: Hex jewlery box
Yes I am. The thickness of the material is 1 7/8" and the shank of the bowl and tray bit is just barely long enough. I use the same bit on the inside of the lid.Creation in Wood wrote: ↑Sun Apr 16, 2023 8:59 pmBeautiful job Steve. Are you cutting the box from one solid piece of wood
- Creation in Wood
