Just Some Old Floor Boards
Tailmaker
Post by Tailmaker »
Here is another one of my project stories with a bunch of pictures.
My neighbor replaced his hardwood floor with new Acacia floor boards and had several left over, about 4.5" wide and 24" long. I decided to make a box from it with following challenges:
- hidden finger joints and slanted side boards
- a wooden hinge, carved in one piece
- a combination lock that is mostly hidden inside the lid
Since the boards were narrower that the desired box width of 8", I resawed a few boards and glued them book-matched together for the bottom and lid. For the latter, I glued 3 plies of these thinner sheets crosswise for less warp and cupping.
Other materials used are claro walnut for the dial and the lock cover and baltic birch with a piece of olive wood for the lock bar shifter.
Side boards prepared with joint fingers that will be hidden in the finished product:
Carving the hinge barrels:
Special jig for precise hinge pin hole drilling:
Jig in place:
Carving the dial of the combination lock:
Dial complete:
Ball bearings for the dial and detent magnets (in the ring of the dial and the groove of the lid):
Code rings and locking bar of the combination lock:
Box assembly complete:
Detail of the combination lock:
Box Open:
And closed.....
jfederer
Model of CNC Machine: CanCam D23M
Re: Just Some Old Floor Boards
Post by jfederer »
Astounding! My mind boggles at the geometrical calculations involved. And of course the workmanship, as always, is first rate. Ausgezeichnet!
Joe Federer
www.federer.ca
Todd D
Model of CNC Machine: Axiom AR8 PRO V5
Post by Todd D »
Really well done and thank you for the write up, great project
Jimcad
Model of CNC Machine: Alpha CNC 6090 with 4th Axis
Post by Jimcad »
Beautiful!
An absolute masterpiece!
Thanks.
Jim
garylmast
Post by garylmast »
Great looking job. Well done.
Gary
scotttarnor
Model of CNC Machine: Piranha XL , Shark HD520
Post by scotttarnor »
WOW ! Incredible!
Scott T
@scottscnc
scottp55
Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP11.5
Post by scottp55 »
Ho Hum...
Another creative,intricate, and absolutely over the top project by Tailmaker :wink:
The fact that it came out beautiful and I'll have to come back to the pics when my mind is fresh is besides the point! :)
Well done sir!
R.N.
Bobtail Farm
Post by Bobtail Farm »
Never mind "ho hum" from our friend Scott.
Creation in Wood
Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Post by Creation in Wood »
Beautiful box
Great job
Thank You
Doug
