Round chair in walnut
rscrawford
Post by rscrawford »
My daughter wanted a walnut chair for Christmas and so I made this one for her (I may have posted a similar chair I made in butternut and cherry a few years ago). My 'copy' of Hans Wegner's round chair (though I've never seen one in person, only a few pictures and a video of it). Very complex joinery, as none if it is 90 degrees. And the top is rather complex to design and to cut. The mortises for the leg tenons are angled a several degrees, and the rabbet for the seat is curved in all 3 planes.
Russell Crawford
rscrawford
Re: Round chair in walnut
And while I had everything set up for round legs, I made my wife a bench that she's been wanting for a while (for the entrance). The same joinery, but very simple lines and angles compared to the round chair! Not as much design work for the top, because I got lazy and made it simple. The seat is a rectangle, no curves or weird angles.
Russell Crawford
JimmyD
Model of CNC Machine: ShopBot PRSalpha, custom rotary indexer
Post by JimmyD »
You do amazing work. I aspire to be as good as you. Pun not intended.
Tailmaker
Post by Tailmaker »
Beautiful! Not to mention functional...
How much of that is CNC vs. manual?
h9vq9
Model of CNC Machine: bridgeport
Post by h9vq9 »
Beautiful chair and bench great work.
rscrawford
Tailmaker wrote:
Tue Jan 03, 2023 10:08 am
These were pretty much all cnc. The legs were turned on a lathe I have mounted to the bed of the cnc, then transferred to the 4th axis to cut the mortises. The tenons were also cut on the cnc, since they were all different angles. Then I had to make a special jig to cut the rabbets for the seat to sit in, as they were curved in all 3 axis (not something I could easily cut without the cnc).
The pieces for the top were joined with finger joints before carving out on the cnc (2 sided cuts), then the mortises were cut on a special jig on the cnc that held the top at 4 different angles (since the legs with the tenons were angled).
Russell Crawford
Bobtail Farm
Post by Bobtail Farm »
swell work. thanks.
Leo
Post by Leo »
Randal
Sam M. got nothing on you.
Fantastic job
I bet it's all silky smooth - sure does look like it is.
Creation in Wood
Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Post by Creation in Wood »
Great job Russell
Thank You
Doug
tornavi
Model of CNC Machine: MAQUINA CNC ALPHA TIPO 2 USB
Post by tornavi »
Grandisimo trabajo!!
rscrawford
Leo wrote:
Thu Jan 05, 2023 11:04 pm
Randal
Fantastic job
Thanks Leo!
Yes, it is silky smooth! I like to use a danish oil finish, so it still feels like wood. Like all furniture (whether built with a CNC or by hand) I spend WAY more time sanding and finishing than cutting and assembling.
Russell Crawford
Tex_Lawrence
Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.004
Post by Tex_Lawrence »
rscrawford wrote:
Mon Jan 09, 2023 3:27 am
... I like to use a danish oil finish, so it still feels like wood....
Russell, when you apply the danish oil, do you apply many thin/light layers or thicker/heavier layers?
Tex — Crooked Wood Products
rscrawford
Tex_Lawrence wrote:
Mon Jan 09, 2023 11:28 am
ALWAYS thin layers. Wipe on with a clean rag, let it sit for a few minutes, wipe dry with another clean rag. Its not meant to be a surface build up finish. You can still get a nice, durable finish by applying 5-6 coats like this, but it still feels like wood (not plastic). I'll sometimes apply with 600 grit wet paper if it doesn't feel smooth, then wipe dry. If you forget to wipe an area dry, you get a sticky rough mess.
Often for my final coat I will melt together 1/3 beeswax and 2/3 danish oil, and wipe that on as a paste then buff it out. Gives a really nice feel and is durable.
Russell Crawford
Leo
Post by Leo »
Nice,
I use a mix of Beeswax, Linseed oil, and mineral spirits or turpentine
I also use Mineral Oil and Beeswax for foodsafe stuff.
Randall, you are quite an accomplished woodworker.
Post by Rcnewcomb »
Russell Crawford is far more accomplished than I am. :oops:
