I had a piece of walnut burl I scrounged at our local makerspace that was just about the right size for Beki's trinket tray.
After cutting it out, I realized I should have changed it around so I could leave the raw edge of the burl intact. (Though there was some bark intrusion that probably would have fallen out at some point.) A few fine cracks required a bit of superglue.
Finish is Deft spray lacquer. Bits were 1/4" flat end mill for roughing, and 1/4" ball nose for finish. I had about a 9 or 10 percent stepover on the ballnose and I should have gone smaller.
--Rich Farwell
Beki's Trinket Tray
- Model of CNC Machine: CNCRouterparts Benchtop Pro
- Tex_Lawrence
Re: Beki's Trinket Tray
I'm thinking that looks really good. After it gets some use, then there will be plenty of scratches to mask any that you see now.
I don't agree with using the "live edge" for this project. It would make it difficult to use. I think raw edges aren't nice to touch and most likely will crumble in places.
Tex — Crooked Wood Products
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
I expect that the posted order of the 4 images is not chronological. It would seem the live edge has cut fully away.Tex_Lawrence wrote: ↑Fri Oct 21, 2022 10:29 amI don't agree with using the "live edge" for this project.
- Tex_Lawrence
I see what you are saying!
However, what I was referring to without clearly explaining was the following from the OP:
"After cutting it out, I realized I should have changed it around so I could leave the raw edge of the burl intact."
- Vectric Staff
- Model of CNC Machine: Various
Wow that is beautiful! Thank you for sharing that
Beki
Senior Application Engineer - Vectric Ltd.
