Corian/Epoxy Plaque
- Model of CNC Machine: Camaster Stinger SR24
Corian/Epoxy Plaque
This is a plaque I came up with to honor a lady at our church who has been playing the piano, organ and singing
in our choir for 55 years. We honored her at a recognition dinner a month ago.
The plaque measures roughly 16 x 16 and it is 0.5" thick. Since I could not find any solid black Corian I had to create the piano shape as an epoxy inlay, approximately 0.1 deep. I just painted the edges black to match...easy peasy! The clef & rest artwork I purchased online. I simply love doing epoxy inlays in Corian. It is such a nice material to cut, and there is no worries about colors bleeding!
Joe
- TomWS
- Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Re: Corian/Epoxy Plaque
Very striking plaque!
Can you explain your 'inlay' technique a bit? Do you VCarve the inlay region and then pour the mixed epoxy into it? I would expect it to be less even and with bubbles. Yours is immaculate!
BTW, I agree with you on vcarving corian. Very nice material to work with.
- Leo
That is absolutely BEAUTIFUL.
Thank you!TomWS wrote: ↑Wed Nov 03, 2021 9:35 pmVery striking plaque!
Yes, I vcarve out the area to be filled, about 0.1 deep. Before pouring the epoxy I level the piece with shims, otherwise the epoxy flows to one side or the other…not good! After its poured I watch for bubbles and when they start showing up I spray them with denatured alcohol. It does a super job dispatching the bubbles. In the first 20 minutes or so after pouring the epoxy I will usually have to spray two, maybe three times and thats all. I make sure the epoxy mounds up in the carve, then when I go to skim it everything is nice and flat. I hope that answers your question…holler if I missed something.
Joe
Joe
- Model of CNC Machine: Axiom AR8 PRO V5
Really nice work, I also like to cut in Corian and may try your method with epoxy. At the moment I'm experimenting with the zank type of inlay in Corian and it looks promising.
Thank you, Todd.
I have to admit, I too have been wondering how the zank inlay would work. Your results have me even more
excited to give it a try. Thanks for sharing!
Just out of curiosity, what type of glue did you use for the inlay? I have used CA glue to laminate pieces and that worked quite well.
Joe
- TomWS
Ah, I haven't heard of that technique before. Good to know! THANKS!Holzarbeiter wrote: ↑Thu Nov 04, 2021 2:30 amAfter its poured I watch for bubbles and when they start showing up I spray them with denatured alcohol. It does a super job dispatching the bubbles. In the first 20 minutes or so after pouring the epoxy I will usually have to spray two, maybe three times and thats all.
How do you 'skim'? Sand, machine on the CNC, ???I make sure the epoxy mounds up in the carve, then when I go to skim it everything is nice and flat. I hope that answers your question…holler if I missed something.
Thanks for the detailed answer. I'm sure others will be experimenting with this now!
@ToddD, good job on the Corian inlay. Good to know this works as well!
This is a terrific resource!!!
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
I tried epoxy and then ca glue with not so good results, then I was able to get the Corian branded glue the counter top guys use. It is color coded to the white and a seamless result. Very hard to get glue as its only sold to fabricators.Holzarbeiter wrote: ↑Thu Nov 04, 2021 4:28 pmThank you, Todd.
Beautiful job. I'm going have to give your technique a try.
Gary
Gary
- scottp55
Wonderful Job Joe!!
Really Beautiful work:)
R.N.
R.N.
Doug, Gary and Scott, thank you for the kind comments.
Joe
TomWS,
I have a drum sander but I was always afraid of clogging up the sandpaper so I skim it on the cnc.
I set Z0 to the surface of the material (where there is no epoxy) and then set my depth of cut to 0.002
That does a nice job of removing the domed epoxy and making everything nice and flat. When Im using epoxy on
Corian I use an O flute bit as it puts a nice smooth finish on both the epoxy & Corian. For wood/epoxy projects I use
a regular end mill.
a regular end mill.
Joe
- TomWS
You get that smooth mirror finish with your CNC router!?Holzarbeiter wrote: ↑Thu Nov 04, 2021 10:42 pmWhen Im using epoxy on
I agree, O-Flutes are the way to go with plastics.
