Old Logo - New Tricks! (Dragknife Acrylic)
Posted: Thu May 27, 2021 3:44 am
A friend helps another friend restore Corsair aircraft.
Have you seen the add where a couple sits down with the home designer, the wife hands him a bath fixture and says "design a house around this"? Well, this guy has custom milled entire aircraft with less...simply amazing!
Friend 1 saw that I made our airlines logo in plastic with a drag knife and asked if I could do this for friend 2...piece of cake. Off to TAP plastics, check out the cutoff bin: 4" x 20" x 1" thick - OOOH, I can work with this! But I have to cut it. Turns out the muli-tooth high angle plywood blades work pretty well with Acrylic. Then, a headlight restoration kit (Mothers) works really well to polish to edges. A quick internet search for lights and then a piece of "thermally stabilized" Poplar for the base (that's worth a whole other thread) and Voila! 8 selectable solid colors or it can flash/fade (the LED's were only $2!) I hope he likes it!
