Blakely Quinn, daughter of my Niece's best friend died of SIDS at 14-months a few days ago
For her parents: 8" x 8" Pink Corian lithophane, figured red maple base with teak/tung oil finish.
Dale
Lithophane
- dhellew2
Lithophane
Young = time, no money
Old = money, no time
Dale
Dale
- Model of CNC Machine: CAMaster Stinger II
Re: Lithophane
Nice work and details. It will be appreciated a lot.
Charlie
Aspire, CAMaster Stinger II
- gkas
Re: Lithophane
Great job. Nice thought.
Re: Lithophane
Nice job Dale. I've done several Lithophane then 3-D printed them, where the thinnest part is 0.75mm thick (1/32"). How thin do you cut them using Corian?
Gary
Gary
- scotttarnor
- dhellew2
Re: Lithophane
Gary, missed your question until today.
The thinnest part is set to .03" with z set at table.
Since corian and others are not perfectly flat or uniform thickness, I don't recommend setting z-zero at the material surface.
In areas where there are large amounts of white, such as tee-shirts, I usually photo-shop in a little texture, mostly taken from a cloud photo. The natural texture of clouds is not obvious in these areas.
As you cut the material stresses are re-leaved and sometime .03 isn't enough.
If you would like the information I used in the beginning, just search for lithophane pdf
Dale
Dale
Dale
Dale
- Xxray
Re: Lithophane
What a terrible loss & nice memorial, I have done quite a few but kids are toughest of all.
I usually set mine to cut .22 at the deepest parts and zero from the top, not much margin for error. One trick to use to avoid busting through which will ruin the whole thing [and yes I have done that more than once] is give yourself some more slack, say .20 or even .18 deep, then simply sand down the back to get maximum depth [you can tell when you are getting close] Drum sander works great but requires caution, plain old orbital words well too, no lower than 120 grit to avoid leaving any chatter which might show up when lit.
Doug
- Tex_Lawrence
Re: Lithophane
Dale, have you ever had problems with someone/something poking through the thin area and ruining the object? I've had folks poke corners through a thin wood carving. Perhaps the durability of Corian is the solution?dhellew2 wrote: ↑Sun Jun 06, 2021 4:31 amThe thinnest part is set to .03" with z set at table.
... As you cut the material stresses are re-leaved and sometime .03 isn't enough.
I'm sure that 0.03" is why your lithophane stands out with the lighting.
Tex — Crooked Wood Products
- dhellew2
Re: Lithophane
A few of suggestions.
Use your machine to plane a flat spot for the Lithophane carving.
The material is usually slightly curved, not flat, so place with the center on the bed and force the outer edges down and clamp.
If the thin areas (white T-shirt etc.) as a bit of texture to add strength. I use an expanded photo of clouds.
If you use a touch plate, it may not be as accurate as you might expect. I usually manually set the bit to the table but when using the touch pad I need to add a couple sheets of copy paper under it.
The larger the litho the greater the carving/stress issues.
Dale
Dale
Dale
Dale
