Another Name Sign
SteveNelson46
Another Name Sign
Post by SteveNelson46 »
Over the last 4 or 5 years I think I've made about 50 or 60 of these. They seem to be popular with friends and family and a quick and easy evening project. I had some scrap Bocote left over from a yester-year project and thought it would make a good name sign.
Jan.vanderlinden
Model of CNC Machine: Xcarve
Re: Another Name Sign
Post by Jan.vanderlinden »
Very impressive.
Phil
Post by Phil »
That is beautiful. I would like to make some for my 3 grandkids. Can you provide a few details on how you created the cut file. I assume that you created a model with the Create Shop Curved Profile.
Since you have made many you have likely fine tuned the process, chosen a suitable font and ideal specs for the model.
Your help is appreciated.
Phil :)
scottp55
Post by scottp55 »
Beautiful wood AND Piece Steve!! :)
A random act of kindness..
You may forget...they probably won't.
SteveNelson46
Phil wrote:
Wed Nov 18, 2020 2:26 pm
Phil :)
Phil,
I used "Snap ITC" for the font and adjusted the kerning. The 3D shapes were made with the "Create Shape tool". Also, I didn't use a cutout. Instead I used a "pierced" approach by using an offset boundary in the finish toolpath with a limit plane and manual tabs. It's similar to Becki's video on the two sided Marlin. It's a two part project with the name and the base as separate files. I cut the base last so I could sneek up on the slot width for a better fit. To mount the two together I used 5 minute epoxy and a small brass screw from the bottom to hold it in place while the epoxy hardened. Here is a link to the the file. You may use or change it in any way you wish. Show us some pics of your finished project.
Post by mtylerfl »
Hi Steve,
Excellent work, as is usual for you! Very nice!
SteveNelson46
mtylerfl wrote:
Wed Nov 18, 2020 7:57 pm
Hi Steve,
Thank you Michael. Also, a big thank you to all else who commented.
Daniel S
Model of CNC Machine: CAMaster Stinger SR-23
Post by Daniel S »
Hi Steve,
Really like the result. Thanks for showing and posting the files. I will try it out for sure. Also thanks for all the help with my Stinger, I think I'm going in the right direction.
Dan
Phil
Post by Phil »
Thank you, Steve. )
Phil
Aussie
Model of CNC Machine: Axiom AR6 Pro
Post by Aussie »
SteveNelson46 wrote:
Tue Nov 17, 2020 11:48 pm
Very nice indeed, would love to try this and thank you for the files..... now to find the time :D
Creation in Wood
Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Post by Creation in Wood »
Great idea Steve, thanks
Thank You
Doug
