3D luck of the draw
Xxray
3D luck of the draw
Post by Xxray »
Got bored and made this from a walnut glueup that has been sitting around for quite some time [CNC by the way].
Unfortunately, right where her head/hair is there is a nasty rotten knot, I usually like knots but ones like this, obviously, are undesirable.
No way to tell, wasn't visible from either side before cutting. Might be hard for some to tell what it even is, its a nude woman riding a fish inside an ornate frame. Took about 4 hrs to cut with a 1/32 TBN. [Blonde slab running exactly in the middle of her rear was also unplanned]
Was considering profile cutting the frame but I thought it best to just leave it in the block its so intricate, .25 endmill likely would have botched it.
Doug
Creation in Wood
Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Re: 3D luck of the draw
Post by Creation in Wood »
Interesting project Doug
Thank You
Doug
