Hello,
I use CNC and aspire to make rosettes and marquetry for my guitars. Here's the type of work that's done.
The inner piece is a wood medallion that's glued into the sound hole. a simple profile path with a 60 degree V-bit. The outer piece is routed with a pocket path then filled in with a colored rock and glue.
Here is another of similar style:
Visit our website to see some guitars: Portland Guitar
Guitar Art
- Model of CNC Machine: Laguana IQ Pro ATC
Re: Guitar Art
Nice work! Thanks for posting.
You might be interested in the Fret Board Maker gadget that handles radiusing and muti-scale fan-fret designs. It was written for V9.5 but it seems to work for V10.5 as well.
Re: Guitar Art
very interesting I'll check it out. How do I download and a gadget and install it into aspire? I can't seem to find where to download it. I've never used gadgets before so I need some help.
- Model of CNC Machine: Home built designs - 3'x4' and 5'x12'
Re: Guitar Art
I like to use Aspire and Celtic knot designs to carve openings in salad bowl guitar tops. Take a look at this example: viewtopic.php?p=226886#p226886
If you don't want to reduce the sound hole area then enlarge the design somewhat and make the knots a bit thinner in width so the holes are larger. I have used my own creations of 3d carved chair cane weave models as sound holes also. Fun stuff to play with.
CarveOne
CarveOne
CarveOne
Re: Guitar Art
Documentation for the Fretboard Maker Overview
Here is the gadget. You can either
unzip to gadget folder
or
Rename the .zip extension to .vgadget, then inside Aspire or Vcarve use the menu to select Gadgets/Install New Gadget...
or
