Cryptex
Cryptex
The box is white oak. The compass rose is maple, cherry, and walnut. The cryptex itself is stabilized purpleheart and stabilized maple. The rings are two pieces with 26 half holes on the purpleheart and 1 half hole on the maple ring. To set the code, you rotate the outer ring to the position you want and insert a pin in the hole to set the letter for each ring. I have mine set to my wife's name, so "THE BOSS" cut into the lid is the clue for unlocking the cryptex.
- mtylerfl
Re: Cryptex
Fantastic project, Wiley! Beautiful work!
- Model of CNC Machine: CNC 6040, Vectric Aspire, UCCNC
Re: Cryptex
Amazing. Doing a Cryptex is on my bucket list.
I have the plans and I have transferred some of the plans to Aspire.
Now I need to set aside some time to finish that.
- gkas
Re: Cryptex
Nice. I like it a lot. Great project.
- mtylerfl
Re: Cryptex
Wiley,
What do you mean the purple heart and maple are “stabilized”? Vacuum resin treated?...or something else? (such as allowing wood to sit awhile before using it)
Re: Cryptex
Wow can't describe it enough. Great Job!
Gary
Gary
- scottp55
- Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP10
Re: Cryptex
A really beautiful piece of work!!
Well Done!!
Well Done!!
A random act of kindness..
You may forget...they probably won't.
- Model of CNC Machine: Shapeoko 3 xxl
Re: Cryptex
Aln incredibly beautiful job, I admire you. BRAVO!
Re: Cryptex
Awesome project, nice job!
Re: Cryptex
Very well done.
Phil
Phil
Re: Cryptex
Mike, where did you get the plans?mickecarlsson wrote: ↑Thu May 28, 2020 7:24 pmAmazing. Doing a Cryptex is on my bucket list.
Phil
Re: Cryptex
Thanks yall it was fun to build. Michael, the parts were vacuum resin stabilized. I roughed them out first then stabilized and baked them. It keeps the thin maple rings from warping.
- mtylerfl
Re: Cryptex
Excellent! Thanks for the info!
Re: Cryptex
Doesn't matter how long you've been on this forum, there's always something to learn. I do a lot of models from MDF, which is very weak and each time I tell myself I need to use something else. I've tried the Minwax wood harder, but that's just for the surface only. I'm going to buy the Vacuum Chamber Kit and other goodies that go with, which seems fairly cheap from Amazon. From the videos I've watch on YouTube, I think this would be a nice addition to my shop equipment.Thanks yall it was fun to build. Michael, the parts were vacuum resin stabilized. I roughed them out first then stabilized and baked them. It keeps the thin maple rings from warping.
Gary
Re: Cryptex
I got them from a gentleman on Internet, he had done a Cryptex in steel and aluminum. I mailed him and asked for a copy of his design and I got a PDF in the mail.Phil wrote: ↑Fri May 29, 2020 1:20 pmMike, where did you get the plans?mickecarlsson wrote: ↑Thu May 28, 2020 7:24 pmAmazing. Doing a Cryptex is on my bucket list.
Phil
I am not sure if I can post it here, I will check and get back to you.
Found it: https://www.youtube.com/watch?v=C8yUaA7F7RI
