My previous post of a Coaster turned to a Trivet as the cuts were through the piece I didn't think it would make for a very effective coaster.
The scaled up Trivet is a seven inch diameter piece made with a Cherry center and a Padauk ring 3/4" thick.
Coaster turned Trivet
Re: Coaster turned Trivet
That is very nice...joe
- Model of CNC Machine: Camaster Stinger SR24
Wow, that turned out beautifully!
I love the wood selection and the monogram.
Any chance you'd be willing to share the cry file?
Joe
- Model of CNC Machine: Probotix Meteor 25 x 50
That's awesome !!!! I could use that, the monogram is right too !!!
Dave
Dave
- rtibbs
- Model of CNC Machine: Shopbot desktop
The vectors were pretty easy to configure however, the files are attached for your use.
Depending on your choice of materials and thickness you should check all the settings and adjust to your preferences.
These worked for me however, I'm pretty conservative on my settings. (Never in a hurry, all I have is time)
I found that with the I.D. on the ring at 5.508" and the O.D. of the insert at 5.500" that was a good fit for gluing the two pieces together.
- gkas
That looks really nice with the extra touches like the contrasting ring and monogram. Good job.
rtibbs2018 wrote:The vectors were pretty easy to configure however, the files are attached for your use.
THANK YOU!!!! I will be sure to give due credit for any I make.
Joe
