Is it a vice to want a nice vise?
BigC
Model of CNC Machine: Workbee
Re: Is it a vice to want a nice vise?
Post by BigC »
What more can one say,
I live in awe.
Such beautiful workmanship
Thanks for bringing his to fruition
Regards
C
scottp55
Post by scottp55 »
Thanks Bill:)
The guy with the pick-up has a good eye for wood(AND you for picking those pieces:)
Love that black streak, as some of my Maple blowdown has similar, and really like how the figure shows through depending on viewing angle!
Like how you shaped the top of that in attempt to save your knuckles :)
Glad you chose oil so very easy to touch up knicks/dings....Yep...a light scrape will do wonders on the old growth legs.
I'm still in awe of the difference between old growth, and the replacement GMO leg in the density of growth rings!!
Your pics made me aware of it, and still think of it...maybe show those pics for the Wood Ticks like me? :)
Uncaffeinated, but just smiled at the thought that you ought to string up halogen track lights to pinpoint the fancy wood like in a Gallery...
AND to bring out the grain of your projects when they're clamped :D
(I have to turn off my LED and rely on the halogens to see figure correctly when facing or cutting 3D firewood)
Is next job your Gramp's Masters toolbox replica?
BillK
Model of CNC Machine: CNC Shark Pro Plus
Post by BillK »
This is what Scott mentioned. These are all 2x10, the grooved ones from my uncle’s bench that I cut down for the legs of my new bench. The one on the left recently purchased from HD. The right ones are at least 70 years old. You can probably fit 3-4 years of growth rings from the old between the Genetically Modified rings of the new. Will new homes built today last as long as those from 70 years ago? Time will tell us.
BillK
https://www.facebook.com/CarvingsByKurtz
BillK
Post by BillK »
“I built it one piece at a time” -Johnny Cash
Sometime in 2018 I was offered a 1 3/4” thick, 36” by 6’ long used maple work bench top. It had scratches and dings in it but looked pretty flat so I agreed to take it home. Two strong guys walked it out of the building to put it my truck. It was heavy, and being not that far removed from hernia surgery I wondered if I made a huge mistake. Well, I got it home, and walked it slowly from my truck bed to a wall in my garage where it stood up for months. Every day I looked at it and thought how was I going to move that thing down to my shop in the basement?
Finally end of October 2018, I put up a couple of saw horses, got out my Dad’s ‘60’s-‘70’s vintage black and decker circular saw with a new diablo blade and a really straight board and ripped a piece from each side to get it down to 24” wide. Took those two smaller parts down stairs and wrestled the big part back up against the wall.
Spring 2019 came and I strapped the big part to a garden cart, put two ramps down the steps to the basement and slowly slid it down. I put it on two saw horses and started working on it, literally, using the top for making other projects on as it was heavy enough to be pretty stable clamped to saw horses. Intermittently I tried planing off the old finish which was very tough, creating tearout. I ended up buying a cabinet scraper and that was a godsend as I scraped the top down. I laminated the rails I had cut off to the bottom, creating a 3 1/2” thick top on both sides. I cut down both ends with a circular saw, router, chisels, and router plane to make the breadboard ends adding the walnut accent pieces.
The rest is well documented in the rest of this post. Today I put the second coat of Tried and True Danish oil on the whole bench. I wheeled it into my basement rec room to take “Glam shots”. I never did get any help moving this, but figured out how to wheel it around and flip it over, etc. Now its done. I’ve been using it and It’s great. If it look disproportionately high to you its 40” tall as I am 6’5” tall. Overall its 24” x 73 1/2 by 40” tall. I might add a deadman to the front if I need to, but not right now.
Oh, you might notice my little bench top bench in a few of the pictures to follow. Love that also built within the last two years. The front is a Moxon vise which is great for cutting dovetails on. That was done almost all by hand, lambs tongue and all. The turning wheels for the screws were done with Aspire, and the little walnut covers on the sides also.
I’m grateful to have been given most of this wood and to have saved it for this project.
Thanks for looking!
How it all began
How it all began
The front
The front
BillK
BillK
Post by BillK »
Some more shots.
BillK
BillK
Post by BillK »
That’s all folks! Thanks again.
BillK
scottp55
Post by scottp55 »
Thanks for that Wood shot Bill.....I wonder which wood engineers use when computing wood trusses...GLAD I told mine to double the snow load Code!
What a wonderful job and documentation you did on this project!
The Aspire and CNC "Touches" as well as the wood choices and the fact a lot was repurposed makes it Really special!
Beautiful job, Well done:)
LIKE the "Glam" shots :)
Great Craftsmanship Bill, for both you and future generations!
BillK
Post by BillK »
Thanks Scott and everyone for your comments and encouragement. If not for your feedback keeping me going, that top would still be on the saw horses. I just want to let everyone know it just takes time and patience and encouragement. A lot of things on this bench project I had never done before. Read, watch videos, look at other projects and with a few inexpensive tools you can do a lot.
BillK
