Twisted Candle Holder
SteveNelson46
Post by SteveNelson46 »
I made a set of candle holders awhile back when I had a Carvewright. The challenge was to make a set on my new machine. This one is a lot smaller and only has two twists. I started off with a 12" 4 by 4 Douglas Fir fence post and rounded the blank to 1.5" in diameter. The base is 3" in diameter and carved separately. It's assembled with a round mortise and tenon. A right twist for a matched set is next.
Re: Twisted Candle Holder
Post by TReischl »
Looks good! Great finish.
Savannahdan
Post by Savannahdan »
Love the graceful design which adds to the grain and finish.
Post by scottp55 »
LOVE how the grain looks with that design!
Excellent finish brings it out:)
Congrats Steve!
GMH
mebell
Model of CNC Machine: CNC-Shark
Post by mebell »
Did you use a rotary axis or did you do this as a 4 sided carving and hand carve to clean it up?
SteveNelson46
mebell wrote:Did you use a rotary axis or did you do this as a 4 sided carving and hand carve to clean it up?
Laid out in Aspire as a rotary project and carved on my Camaster ornamental lathe
Creation in Wood
Post by Creation in Wood »
Very nice job with a great finish
Thank You
