Twisted Candle Holder
- Model of CNC Machine: Camaster Stinger using WinCNC
I made a set of candle holders awhile back when I had a Carvewright. The challenge was to make a set on my new machine. This one is a lot smaller and only has two twists. I started off with a 12" 4 by 4 Douglas Fir fence post and rounded the blank to 1.5" in diameter. The base is 3" in diameter and carved separately. It's assembled with a round mortise and tenon. A right twist for a matched set is next.
- TReischl
- Model of CNC Machine: 8020 Build 48X36X10 RP 2010 Screenset
Re: Twisted Candle Holder
Looks good! Great finish.
Love the graceful design which adds to the grain and finish.
- scottp55
- Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP10
LOVE how the grain looks with that design!
Excellent finish brings it out:)
Congrats Steve!
Congrats Steve!
A random act of kindness..
You may forget...they probably won't.
Did you use a rotary axis or did you do this as a 4 sided carving and hand carve to clean it up?
Laid out in Aspire as a rotary project and carved on my Camaster ornamental lathemebell wrote:Did you use a rotary axis or did you do this as a 4 sided carving and hand carve to clean it up?
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
