Aluminum Molds
John Murphy
Model of CNC Machine: AXYZ 5010
Aluminum Molds
Post by John Murphy »
Hi Guys.
It's been awhile since I posted.
I've been doing prototype molds for a filter manufacturer the past couple of years.
Here's a couple of the latest.
Designed and machined using Aspire.
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Re: Aluminum Molds
Post by jimwill2 »
Nice work! Are you machining those dry?
Jim Williams
dwilli9013
Re: Aluminum Molds
Post by dwilli9013 »
Pretty impressive. Finish looks to be spot on. Thanks for sharing.
D-Dub
Dwayne
Dwilli
John Murphy
Re: Aluminum Molds
Hi Jim.
The answer is no. I have 2 misters mounted on my machine. I use one for a water soluable coolant, and straight air on the other.
I only use 6061 or better aluminum which makes machining allot easier.
stankern
Re: Aluminum Molds
Post by stankern »
well done john , looks excellent
PaulRowntree
Re: Aluminum Molds
Post by PaulRowntree »
Looks very good John! What feeds and speeds do you use on the AXYZ?
Paul Rowntree
John Murphy
Re: Aluminum Molds
Hi Paul.
I run in the 150-200 ipm range for roughing and finishing.
