Page 1 of 1
Small Birthday plaque
Posted: Wed Jun 08, 2016 2:01 am
by basecircle
Hi everbody .This is no big deal.It's a pine Birthday plaque for my Grand daughter.I put a small frame around it. Just used a 60deg cutter cut to a depth of .060 Pre sprayed a sealer on and then cut.Shot some black ink. sanded it and cleared it.She loves it. Basecircle
Re: Small Birthday plaque
Posted: Wed Jun 08, 2016 2:17 am
by highpockets
Great job! Neat that you created the sign and frame all in one.
Did you seal, cut then seal again before spraying the ink on?
Posted: Wed Jun 08, 2016 5:34 pm
by basecircle
Thanks High pockets. To answer your question I sealed cut and sprayed on the Ink. After cleanup I sprayed.The first sealer is to close the grain and when you ink it.there is no bleed. Hope this answered your question. Basecircle
Posted: Thu Jun 09, 2016 5:33 am
by highpockets
basecircle,
Thanks it does. What are you using to seal the wood?
Posted: Thu Jun 09, 2016 1:12 pm
by martin54
Now I would have to disagree with that, the fact that it was done for your Grand daughter & she loved it makes it a big deal, doesn't have to be something really elaborate to be a big deal as far as I am concerned, sometimes the simplest of things are the best
Anyway, great job in making your Grand daughters birthday extra special
Posted: Fri Jun 10, 2016 2:22 am
by basecircle
Thank you Highpockets.I used spray on clear.Sometimes I use the spray shellack . Try it You will like it. Basecircle
Posted: Fri Jun 10, 2016 2:26 am
by basecircle
Thanks Martin She loves it and that's what matters.I only meant that for this Fourm It was not a big deal.Cause alot of the work I see has many hours. Anyway Than k you.And keep cranking the work out. Basecircle
Posted: Fri Jun 10, 2016 8:58 pm
by BArnold
Nice idea and execution!
You give me some ideas for plaques I need to make for some of my grandkids.
