Aluminum Plaque
Aluminum Plaque
Its been a while since I posted one of these.
Machined from 1/2 7075 T6 aluminum. 20" long on a Fadal 4020 VMC using Aspire.
Inlayed Challenge coins. These are the same coin in a heads and tails arrangement.
Dyna CNC Plasma/Router
USAF-- Fadal 4020, Shopbot PRT 4X8
- ChrisInEstes
- Model of CNC Machine: Vytek 4' X 8' - Perske Spindle - Mach3
Re: Aluminum Plaque
Nice work!
I've always been afraid to cut aluminum on my router... Maybe one day I'll get it figured out.
Thanks for posting that!
Chris
Chris
- bill_w
- Model of CNC Machine: PRSalpha BT48
Re: Aluminum Plaque
Very, very nice , well done. What kind of paint did you use?
Computers-Yuk....I should junk it...It never does what it should do...only what I tell it.
Re: Aluminum Plaque
Thank you very much.
Bill, beleive it or not the paint is Rustomeum rattle can. Some are their Metallics and some are not.
Thanks again
Kelly
Thanks again
Kelly
- T.R.MacMunn
- Model of CNC Machine: CAMaster MC4836
Re: Aluminum Plaque
Kelly, that is an AWESOME plaque. Very well done ........
- bill_w
Re: Aluminum Plaque
Thanks Kelly,
Aluminum is hard to get paint to adhere to
especially if there is coolant involved.
Re: Aluminum Plaque
Thanks T.R. I appreciate that.
Bill, I always glass bead blast these before paint. If I cant fior whatever reason, I will use a brass brush and scotchbrite to scuff it up.
The only color that I had problems with was gold. I certainly have to scuff or blast for that. I certainly ageee with the coolant. I use flood coolant on the Fadal with full enclosure.
Kelly
Kelly
- esteeme1
- Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Re: Aluminum Plaque
Awesome work as usual Kelly.
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
"Can Do!"
- Woodbug
- Model of CNC Machine: Blurry Customs
Re: Aluminum Plaque
Very nice. I have novice a question. After you apply the paint, how do you finish the surface. Is it fine sanded, wet sanded or milled?
Re: Aluminum Plaque
Thank you very much Jim.
Woodbug. I start by glass bead blasting the entire part when all possible. Next I use a 4inch sanding block with 80 grit DA paper to sand out the toolpath marks. To do this I sand back and forth in a straight line. Make sure not to move over or side to side because this will cause crosshatch sand scratches that are more work to get out. When you are ready to move over, lift the block and then move over. Once the tool marks are out I mask and spray the areas. To remove the excess paint on top I repeat the steps above again using 80 grit. Once the paint is removed I start sanding in one direction only. (Usually pushing the block away from me) This allows me to control the control the straightness of the grain and even the grain pattern out across the part. The final step is to use about a 4 inch-ish piece of Maroon Scotchbrite, sanding in one direction slowly. This blends any grain irregularity out and also soften the grain coarseness. The result is what you see here.
I have stepped down to 120 or 220 before and looks good but the 80 grit and scotchbrite is my favorite.
I hope this helps.
Thank you
Kelly
I hope this helps.
Thank you
Kelly
- Woodbug
Re: Aluminum Plaque
Thank you for the detailed explanation.
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
Re: Aluminum Plaque
That is a beautiful plaque. Very well done.
Russell Crawford
- fretsman68
