Pizza Cutter!
- BSImages
- Model of CNC Machine: Home designed and built.
Pizza Cutter!
Now this is a pizza cutter on steroids!
It is Red Oak and Poplar laminated together with a 1/2 Oz. domed copper bullion coin for an accent.
With it's 4" cutting wheel it will cut any pizza it come across!
- mikeacg
- Model of CNC Machine: Camaster Stinger, Sidewinder, SB 4x4
Re: Pizza Cutter!
I don't eat pizza but that is so cool I may have to try to make a steampunk version of it just to show off!
Good job!
Mike
Good job!
Mike
- BSImages
4-Up 2 Sided Cut Pizza Cutter 3D!
4-Up 2 Sided Cut Pizza Cutter in 3D!
- esteeme1
- Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Re: Pizza Cutter!
What do you mean you don't eat pizza?
Nice Job! Don't change a thing.
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
"Can Do!"
- Model of CNC Machine: Home built
Re: Pizza Cutter!
Nice job!!
That handle design could be converted to use for a walking stick also?
Cheers,
Kym
Cheers,
Kym
Re: Pizza Cutter!
Nice design for a pizza cutter. I like how it forms to the hand. The design could be used on other stuff that needs a handle. Thanks for showing it.
Tony
Tony
- BSImages
Re: Pizza Cutter!
I originally designed it as an ergonomic walking stick handle and it worked so well at that, that I thought I would give a try on a pizza cutter...
- Model of CNC Machine: Camaster Panther 4x8
Re: Pizza Cutter!
Looks good. Pass the pepperoni, please.
- mtylerfl
Re: Pizza Cutter!
Great design, Bill...mighty handy, too!
Re: Pizza Cutter!
I like the look of that cutter.
Just one thing I see that might improve the project. If you flip and turn every other handle you could get more handles out of the same size stock and would lower the cost of each cutter.
- Model of CNC Machine: CAMaster 508 ATC
Re: Pizza Cutter!
Lord that looks like an excellent tool,, having stuck my thumb in the same tablesaw twice, it scared the %$&* outa me !!
- BSImages
Re: Pizza Cutter!
I tried that, but with two sided cutting and the use of tabs made it too unstable for an accurate cut.mebell wrote:I like the look of that cutter.
- BSImages
Re: Pizza Cutter!
Here is the work in progress...
